200 4r vs. 700 r4
Old Dec 19, 2009 | 11:43 PM
OD_85'305_SS's Avatar
Cool 200 4r vs. 700 r4
please i need help my trans is going an its time to upgrade !!
im between rebuilding my 200 4r
or buying a rebuilt 700 r4
they both come out to about the same price
depending on whether i do the work my self or not (never done it b4 hoping 4 the best)
but does anyone have any pros and cons
an does anybody the weight of these trans
Old Dec 19, 2009 | 11:59 PM
RocknSS04's Avatar
I'm not an expert here, but I don't think a 700R4 will fit in the car (in the tunnel). A 200R4 can be built strong, anyways. It's all in the parts used. Make sure you have race worthy parts.
Old Dec 20, 2009 | 10:50 AM
Budsjlm's Avatar
Go check out montecarloss.com i know people have ran 700r4 and has a bunch of usefull stuff on there on rebuild of 200r4 and 700r4 swaps
Old Dec 20, 2009 | 11:25 PM
drewskie043's Avatar
the 700 will fit, i've seen a handful of montes that have them. but, IMO i would go with a WELL BUILT 200r4 because it will bolt in with no problems or modifications (obviously b/c it's the stock trans). with the 700 you are looking at spending time/money on a trans crossmember relocation and different length driveshaft since it's a tad longer than the 200.
if you can get them built for the same price, save yourself the time and hassle and use something that you KNOW will bolt right up. i've heard of ppl building 200s to withstand 500-600hp so you should be covered there. i've even seen them bolted to big blocks. just tell the shop what your estimated hp will be and they can fix you up. good luck!
Old Dec 21, 2009 | 12:11 PM
TheMonteMan's Avatar
the 700 fits im running one. you are correct it does require cross member and driveshaft work nothing major though. i like it and they can take some brutal power but they have to be built to do so. my brother and i run them behind n2o motors with out a problem. they have there draw backs though. if you already have the 200 though have it built up. heres a link for a good artical on it. goodluck.
http://www.carcraft.com/techarticles...ons/index.html
Old Dec 21, 2009 | 01:36 PM
sideways's Avatar
I would most definatly rebuild the 2004r, better gear spread. The rpm drop between 1-2 on a 700r4 is just to much.
Old Dec 22, 2009 | 04:41 PM
thanx alot everybpdy
i think i am going to rebuild my 200 4r
now the problem is the funds
but ill c wat i do
Old Jan 11, 2010 | 07:47 PM
Bob's Avatar
Bob
I own an 86 ss with the 200, this trans can be built to handled up to 600 hp, thats the max that you can build this trans too. Also put in a Zr1 2400 stall converter.
Old Jan 13, 2010 | 09:57 AM
wottreng33's Avatar
To answer all your questions I have a magazine of Car Craft, October 09 issue that has the article all about overdrive trans:
TH200-4R- no computer required, can be built to handle 1000hp. OE rating of 300hp
Weakness= most of the internals will need to be replaced to handle alot of power.
TH700-R4- dont need computer but can, can be built to handle 700-1000hp. Huge aftermarket support. OE rating of 350hp
Weakness= big rpm drop between 1st and 2nd gear (can be changed), sun shell tends to break at input shaft splines.
Hope this helps.
aw9d
13
Oct 31, 2009 07:46 PM
manny
Mar 26, 2008 06:06 PM
BeachBumMike
Mar 15, 2007 01:23 AM
