1999 monte 3.1 A/C help needed
Old May 26, 2011 | 09:22 AM
mplsmike's Avatar
Default 1999 monte 3.1 A/C help needed
Had a leak in the a/c line hoses and replaced them, couldn't get the compressor to run so jumped that and it did. put in 2 cans of refridgerant in and plugged the relay back in. Compressor still will not kick on and checked the low pressure switch which tested good. The auto parts people said it sounded like the control switch inside of the car is bad, does that sound like a possibility or has anyone else had a problem like this. Could use and and all help.
Thanks
mplsmike
z34phantom
May 15, 2014 01:46 PM
MCarlo99
Aug 19, 2012 03:57 PM
Big-O
Jun 4, 2012 03:00 PM
caffeinegamer
Mar 3, 2007 06:41 AM
xxMoNtEdRiVeRxx
Sep 2, 2006 08:44 PM
