1997 Chevy MC won't start....HELP!
Old Aug 1, 2006 | 01:47 PM
taceyburd's Avatar
Default 1997 Chevy MC won't start....HELP!
I have a 1997 Monte Carlo. It currently is not starting. I'll turn the key and the lights will come on but nothing else happens. I'm wondering where the problem might be and what i need to do. I've checked the starter battery alternator solenoid etc. and still nothing. Have u heard of anything like this and what can i do? Hopefully its a DIY thing......
Old Aug 1, 2006 | 02:54 PM
montejass's Avatar
Default RE: 1997 Chevy MC won't start....HELP!
Is the starter making any noise at all?
Old Aug 1, 2006 | 02:55 PM
taceyburd's Avatar
No
Old Aug 1, 2006 | 03:25 PM
montejass's Avatar
Have you tested the starter?
If not, pull it and run it over to AutoZone or the like, they will bench test it for free normally.
More importantly, double check the battery and all cables running to and from the starter. Corrosion can be a troubleshooting nightmare.
Old Aug 1, 2006 | 07:31 PM
Maverick's Avatar
its most likely the engine control fuse those things can blow for no reason everything will be fine but no power can get to the started check that and all the other fuses to good luck ,that fuse went out on my buddies jeep and had us stumped for a couple days lol.
Paige Marie Prouty
May 25, 2013 07:29 PM
zlbh08
Jan 27, 2013 10:32 PM
ChevRev34
Feb 24, 2008 01:10 PM
gator101
Aug 22, 2005 03:43 AM
gator101
Jul 22, 2005 06:24 PM
