1995 montecarlo 3.4 vin x what part is this
Old Jun 18, 2012 | 12:43 PM
pat1973's Avatar
Default 1995 montecarlo 3.4 vin x what part is this
http://s1061.photobucket.com/albums/t479/plgrimm/
i have a 1995 montecarlo 3.4 vin x under the intake manifold there is a
cover with 7 bolts with a nipple that a vacume line connects to does anyone know what that part is called i need to get a gasket it is leaking oil thank you for your help
Old Jun 18, 2012 | 01:23 PM
Budsjlm's Avatar
I say just clean it up and it's matting surface and RTV it and call it a day,,
Old Jun 18, 2012 | 01:29 PM
Looks like you need gasket <TABLE style="WIDTH: 100%; BORDER-COLLAPSE: collapse" id=ctl00_Content_PageBody_gridview_assemblyProduct s border=0 cellSpacing=0 cellPadding=5><TBODY><TR style="BACKGROUND-COLOR: rgb(247,247,247)" class=productKeyRow vAlign=top align=left><TD align=center>443</TD><TD align=left>24506744
</TD><TD>GASKET. Engine Oil Distribution
GASKET,ENG OIL MANIF. Required: 01
For: W 3.4X(LQ1) (1993-1994) (1994 - 1994).
For: W 3.4X(LQ1) (1993-1996) (1994 - 1995).
For: W 3.4X(LQ1) (1995-1997) (1995 - 1995).
</TD></TR></TBODY></TABLE>
Old Jun 18, 2012 | 02:42 PM
pat1973's Avatar
443 is it thank you all very much on order!!!
Old Jun 19, 2012 | 02:37 PM
z34phoenix's Avatar
double check that this was actually the source of the leak... there is a plug to the right of this cover. it is just toward the driver side. this is the Oil pump drive shaft. this block was designed to have a distributor and this plug covers where it would have went. there is an O ring that fails here. the same part is to remove and replace this oring you need to pull the rear head! the solution most do is clean it up and raise it enough to pump RTV around it. this solution rarely lasts longer then 3-6 months. what i did to solve the issue was get Quick Steel epoxi... its kinda like JBweld and formed it into a donuts and sealed the cap back down. it solved the leak. and lasted the rest of the life of the motor. it ran to 224,000 miles i think i sealed it when it hat 150,000 miles.
pat1973
Jun 22, 2012 08:01 AM
LunarQuartz07
Dec 28, 2011 05:39 PM
golfstud2k4
Sep 29, 2010 03:37 PM
dkadr316
Oct 17, 2007 06:54 PM
