06 SS thinking manual tranny. opinions?
They are somewhat similiar..Kinda
Im guessing thats why, because of costs..and size like you said
Trust me, stick with the front wheel drive configuration, unless you got an extra $12,000 to convert yours into a manual or a rwd streetable like my car... Check me out. Im on here, member name; "2000MonteCarlorwd".
Dont know where you live but many local trans shops can do certain things to make those transmissions a bit tougher, like any other trans...
reportedly cost 80% more than a similar GM 4T60 transmission and weighed 60 lb (27 kg) more.
-How much power is that C4 IRS supposed to be able to handle? (especially with the extra weight)
-What did you use for engine mounting up front, and why'd you mount the engine so far back like in a camaro?
-Any other pics of how the rear end bracing and such is set up?
- The 4T80 is reserved for the luxury models - Cadillac and Buick (although was also used in the Pontiac Bonneville). It was designed to match the Northstar V8.
- Good luck getting a manual in there. There is very little packaging room for anything, much less a manual. GM's 4-speed design is such that the gearsets and clutches wrap around the back of the engine and the only components in line with the crankshaft are the torque converter and chain sprocket. I would like to figure out a way to get a 6T70 in there, personally, but there's just not enough width in the W car engine compartment.
Uhhh who would do that??? *looks around nervously*
Jimmy Criswell
08-06-2013 02:44 PM
slinkeey
02-03-2009 10:33 AM
