06 mc engine swap?
Old Jan 11, 2008 | 12:51 AM
monte06v6's Avatar
Default 06 mc engine swap?
hey just wondering if anyone had any ideas of a engine swap i could do on my 06 monte carlo give me ideas thanks
Old Jan 11, 2008 | 02:04 AM
kweef's Avatar
Default RE: 06 mc engine swap?
i take it u want more hp...and what do u have an ss or ls
Old Jan 11, 2008 | 06:41 AM
Cowboy6622's Avatar
i'd take it from his name he gota V6... probably looking at a V8. keep in mind if you go with the V8, i know they have different transmissions and they probably have a heavier duty suspension to hold the engine.. plus more than likeley a different wiring harness. its not as easy as back in the day when you just pulled one out and popped a new one in.
the 5.3 would probably be tricky, considering it has the DOD system that shuts down 4 cylinders.
the NorthStar V8 from Cadillac isn't as good as the 5.3
a 3.8 supercharged has alot of potential.. but I don't know about getting on in the 7th generation 06-07's..
Old Jan 11, 2008 | 11:52 AM
GrandPaDave's Avatar
I think a crate motor would rock!
Old Jan 11, 2008 | 03:01 PM
rj's Avatar
rj
Get's my vote.
Old Jan 11, 2008 | 04:57 PM
04 Intimidator's Avatar
ORIGINAL: SolaraSlayer
X2!!!
Old Jan 11, 2008 | 04:59 PM
Instead of going with a different engine which will cost you about 7 grand plus tons of programming headaches I would go with a turbo. Bring it to ZZP andthey can hook you up with a setup for 4-5 grand and it will be more powerfull than the larger engine and will be less of a headache.
Old Jan 12, 2008 | 01:11 PM
RocknSS04's Avatar
I'm a BIG fan of boost! Turbocharge that sucker and make it GO! The 5.3's are a rare breed, being shorter than a truck engine, or an LS1 or LS2. The milage on them as stated here just plain sucks, and boost is KEWL!
Budsjlm
Apr 3, 2012 05:43 PM
HaRvArDaLe
Nov 3, 2006 08:00 AM
goat
Feb 19, 2006 11:58 PM
batman
Feb 16, 2006 03:18 AM
rchurch
Apr 29, 2005 05:49 PM
