6th Gen ('00-'05): 05 Monte Carlo Ls loss of power
Old Jun 24, 2014 | 04:30 PM
Shayrae's Avatar
Default 05 Monte Carlo Ls loss of power
3.4L 100xxx miles
Recently experiencing loss of power when driving. Accelerates fine at low speeds but at over 50 mph its hard to get it to speed up or maintain speed. Check engine light has not come on and there are no codes.
Where should I start looking?
Old Jul 2, 2014 | 11:27 PM
MonteLSV6's Avatar
Any vacuum leaks? When I had a vacuum leak in the engine bay, I had no troubles accelerating, but when higher speeds 50+, it had trouble gaining speed.
I'd check to hear any hissing noises under your hood..while you're there, check for any debris behind your driver side headlight that might be blocking your intake opening.
It's hard to tell (for me at least) from given decription, but I'd start with that.
Old Jul 3, 2014 | 10:42 AM
Another thought, possibly your cat is clogged, after driving look under the car to see if its glowing red at all.
Old Jul 3, 2014 | 12:11 PM
Habbibie's Avatar
When was you're last tune up performed?
Shane1987
Oct 4, 2012 09:22 AM
RedZed
Apr 21, 2009 05:06 PM
echolmberg
Sep 5, 2008 10:39 AM
lisacan2
Jan 15, 2007 12:27 AM
Matthew
Jun 19, 2005 03:25 AM
