02 monte ss
I have a bone stock Monte Carlo SS other than a cold air intake. I want to put a exhaust on it. I have seen several videos. And magnaflow seems to sound the best. Just not sure what size I want to go to. If I should do a 3 inch exhaust or not. Does anyone have any opinions on this. I'm sure it is largely takes about. Any help would be amazing. Thank you!!
Magnaflows are gonna give you the most/best sound for your money. I have borlas and a resonator delete which is the best sound iv heard by far but darn expensive. Haha. Unless you plan on turbo or supercharghing leave it with a 2.5" exhaust. The 3" isn't going to do your exhaust gasses any gpod beacuse they will still be having to squeze out the stock exhaust manifold, then through the crappy GM down pipe and around the O2 sensor u-bend. For behind the cat, unless its a show car, just focus on mufflers. If you want some performance boost look at the exhaust system before the cat to get the most for you're money.
get the magnaflows first and see how you like the sound. If you want more than a res delete is $70.
