Diy fuel pump?
Old Dec 3, 2011 | 04:45 PM
sotmelo's Avatar
Exclamation Diy fuel pump?
So i Have a 2001 SS and i just got a new fuel pump, i just need a little help with the install, anyone have a Do it yourself link or can help?
Old Dec 3, 2011 | 05:00 PM
nitehawkjcb's Avatar
You may want to invest in a Haynes manual, they are very helpful
However, I'm not positive, but I think there is an access hatch under your backseat to get atop the fuel tank and remove the assembly. If not, you have to drop the tank.
Old Dec 3, 2011 | 08:48 PM
Mike 00LS's Avatar
There is a hatch - 6th gens can catch it through the trunk - you just have to take the lining out of the trunk. As far as where, not sure since I've never accessed it but others who have done this have said that's where it is.
Do a forum search, I've seen threads on it before.
Old Dec 3, 2011 | 09:03 PM
The hatch is between the rear seat and the spare tire well. Easy to get to (and luckily, I've never had to use it yet).
Old Dec 4, 2011 | 01:44 AM
DRuben's Avatar
Its real easy to take out, just get (i believe) a flathead screwdriver and hammer to turn the cover thingy and remove the 3 fuel lines and pull it straight out...
Old Dec 4, 2011 | 08:49 AM
03SSLE's Avatar
I would suggest renting a lock ring removal tool or a brass drift and a rubber/rawhide hammer instead of a screwdriver. That way you don't run the risk of creating any sparks.
Old Dec 4, 2011 | 09:19 AM
DRuben's Avatar
You know I didnt even think about the chance of creating a spark and setting stuff on fire lol good catch!I always realize the mistakes after ive done the project lol. Be sure to relieve the fuel pressure or you will get gas spraying everywhere like I did lol (in my face). Pull the fuel pump relay (under the hood) and crank it, it still may have a little gas but not as much. Bring some old rags just in case.
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
amberite
Jul 20, 2007 09:20 AM
PCWeber
Mar 11, 2007 10:58 PM
Monte Python
Jul 11, 2005 02:56 PM
