Wax on rubber and plastic
Old Jul 13, 2018 | 08:27 PM
Jeffs02rwdSS's Avatar
Default Wax on rubber and plastic
Wondering what I should use to get wax and polishing compound off of plastic and rubber ? I have tried alcohol on a rag and some bug and wax remover neither did much any suggestions would be great.
Old Jul 13, 2018 | 08:52 PM
I usually had good result with Mother's Back-to-Black. Could give that a shot.
Old Jul 13, 2018 | 09:56 PM
Smile
If you have some Wesley's tire cleaner try that, get the old one they were bought out. get at the hardware store and not at Walmart.
Old Jul 13, 2018 | 11:21 PM
I use a product called "Kleen-Flo Holistic Rubber Care", but I don't even know if you can get that stuff in the US
Old Jul 14, 2018 | 05:18 AM
SuperchargedMonte's Avatar
I am curious did you ever do this with soft rubber around the sunroof? Thanks!
Old Jul 14, 2018 | 06:13 AM
The things suggested above wont FIX your problem.. Theyll cover it up for a week or so. Plus things like to stick to tire shine like dust and dirt..
The only thing I have had luck with actually removing wax and polish off rubber (like around my rear windows) is buffing it out with a dremel tool.. Even that didnt get it all.
I think the wax absorbs into the rubber or a chemical in the wax reacts to the rubber creating a change in the rubber itself..
Old Jul 14, 2018 | 07:23 AM
I've used it on that and other black rubber and plastic pieces. The downside with the sunroof piece, it only darkens a little bit. It does not go full black.
Old Jul 14, 2018 | 01:38 PM
Disagree! The Holistic Rubber care stuff I use is not a dressing at all. It's a thin non-gelling product delivered from a aerosol can and if you spray the crap out of rubber with it enough to get it wet it will all absorb right into the rubber. It's a rubber restoration product designed to make rubber more pliable. It's intended to be used on hoses, weatherstripping and CV boots.
I can't see a Dremel not doing damage, even with just a brush bit
Old Jul 14, 2018 | 03:05 PM
Thank you!
Old May 13, 2022 | 02:12 PM
Suburban73's Avatar
Try a white rubber eraser you can buy at Staples
SteveCZ28
May 28, 2015 09:37 PM
tweek
Mar 11, 2015 12:09 PM
dominic
Feb 2, 2009 07:47 PM
Muddauber
Sep 5, 2007 05:21 PM
zipsayain
Mar 2, 2007 07:10 PM
