Trunk Light
Old Dec 14, 2008 | 01:27 AM
itscsalvo's Avatar
Default Trunk Light
In my 2005 Monte LS, is there supposed to be an interior trunk light? Either mine is burned out and I cannot seem to find it, or there was never one to begin with.
If I have one, where is it located and can I get to to it pretty easily?
If not, I'll pop some LEDs in there or something.
Any help would be rad. Thanks dudes.
Old Dec 14, 2008 | 07:07 AM
RocknSS04's Avatar
Default RE: Trunk Light
I believe it's up by the latch. About 3/4" x 2" clear plastic. Mine has been removed but I'm pretty sure about that. Someone will correct me if I'm wrong. You might not have the light convenience package, as a base LS might not have it.
Old Dec 14, 2008 | 11:56 AM
itscsalvo's Avatar
Thanks for the response, Wayne. I always want to check it out, but it seems like when I remember, it's always dark outside. Same thing happens when I need to get in my trunk. So it's pretty inconvenient, I guess. I'll look into it.
Thanks dude.
Old Dec 14, 2008 | 06:12 PM
inssanity21's Avatar
there is one there right in the center up top. its a piece about 2 inches long and plastic. held in with a couple of clips on each side. very easy to replace
Old Dec 14, 2008 | 06:19 PM
itscsalvo's Avatar
Thanks for the response, man. I would go look now, but it's dark, and approximately -12 or more because of wind chill right now. So.. maybe when it gets warmer.
I parked really far away from my building. Don't want people dinging up my monte.
Old Dec 15, 2008 | 12:37 PM
biggriggs's Avatar
The bulb number should be a 194 if i remember correctly. You just unclip the plastic, but be VERY careful not to break the tabs. They can get fragile depending on age. I broke on on my last car, and it never looked right to me after that. Good thing it was in the trunk.
-Riggs.
Old Oct 17, 2012 | 01:37 AM
Chiran Sigur's Avatar
no bulb size is 912 for the trunk
Old Oct 17, 2012 | 10:31 AM
-Riggs.
Virtually the same thing lol
OP I would replace it with an LED if you have to replace it, some bright white LEDs would be great and you could replace the interior lights while you're at it.
Old Oct 17, 2012 | 10:35 AM
I think a trunk light is pretty much useless....IMO
Thats why they make flashlights....
Old Oct 17, 2012 | 11:10 AM
You guys are answering a question asked in 2008.lol
