Painting my engine cover again!! (3rd one)
#111
Anyone ever use something other than the "stock" padding/deadening material under their cover(s)? Something such as Dynamat, etc., ... especially when aiming for a near-squeak-free environment for quiet ride, & better audio experience, whether hi-end, or what-have-you ... (?)
#112
Padding under the engine cover? No way. I don't think the cover is there for anything other then decoration - its not going to silence crap anyway you go. If anything, it may rattle around a little and make more noise. The engine cover also traps heat - not good. Which is why some try "meshing" their covers. Additional padding would trap more heat, so I wouldn't recommend this.
#113
#114
If you want it to be quiet, dynomat your firewall and the underside of your hood. If its stock heat shouldn't matter as much. I understand heat being an issue on a badass turbo car though
Franks 03SS
10-13-2011 12:08 AM
Mod Guide: Painting your plastic engine cover
Enzo354
FWD Tech Guides '95-'07
18
11-27-2008 11:02 AM
zk6216
10-21-2008 10:44 PM
