driver tail light
Old Apr 30, 2007 | 03:01 AM
domawi84's Avatar
Default driver tail light
I have a problem with my driver tail light. It is loose at the top and still connected at the bottom. I can pull it away from the car at the top and see behind the housing, but it stays connected at the bottom. I have also noticed that when I wash the car, moisture gets in the lens and fogs up. I believe that it needs to be attached at the top, or the whole housing needs replacement. does any one have any ideas?
Doug
dm2willi@oakland.edu
Old May 1, 2007 | 12:16 AM
dad0098's Avatar
Default RE: driver tail light
In the trunk behind the tailight there's some plastic nuts including the net hooks . Try tightening them. That's all that holds them in , plastic nuts
Old May 2, 2007 | 12:14 AM
mickey's Avatar
also the fogging means that the seal is broken on them so if ya want that to stop you have to reseal them or replace them
Old May 4, 2007 | 03:27 PM
06MonteSS's Avatar
same thing happened on mine... except, the plastic part of the housing that contains the threads actually broke off... the plastic nut still had the threads and piece of housing in it... I took everything apart and superglued the threads/housing piece back together with the housing, and so far, so good.
Old May 4, 2007 | 05:28 PM
rj's Avatar
rj
You can also use silicone (such as you find in a tube at Wally World) or an industrial adhesive to glue the housing back together.
gtpshawty
Sep 13, 2013 03:29 AM
shock081
Jul 14, 2010 09:00 PM
gohawk72
Oct 2, 2009 02:14 PM
USMC8825
Oct 2, 2009 02:09 PM
mikeymontecarlo
May 1, 2008 02:41 PM
