Dale Jr #2081 resurrection thread!
#32
i've called gm to see if they know how many came with/without a sunroof and they don't have any information on it (which I don't believe.)
Anyway, made progress in the interior.
Everything has been scuffed up and rust reformed.
And now just after hours of prep work, taping up paper barriers and using a good 2 giant rolls of painters tape.......taken just after 2 fresh coats.
#33
because some bean counter looks at that info to see if they should offer it as an option . I talked to GM to see how many supercharged monte carlo SS where made in 2005. GM said they don't know because no break down for 2005 monte carlo ,code # 1ww27,1wx27,1wz27 , I still think some bean counter knows the break down for this...Because why make diff # 1ww27,1wx27,1wz27 ????
#34
No one wants to look into that stuff anyway...lazy bastards :P
Carpet and console in!
And decoded the RPO sticker. Took a while.. cant decode qs1.
Code:
ag1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER ag2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL ak5 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS ap9 NET CONVENIENCE ar9 SEAT FRT BKT, DELUXE b34 COVERING FRT FLOOR MATS, CARPETED INSERT b35 COVERING REAR FLOOR MATS, CARPETED INSERT cah HANDLING CHARGE OSHAWA ASM TO MAGNA TO OSHAWA ASM cf5 ROOF SUN, GLASS, SLIDING, ELEC cj3 HVAC SYSTEM AIR CONDITIONER FRT, MAN TEMP CONT, AUX TEMP CONT dd6 MIRROR I/S R/V LT SENSITIVE, DUAL READING LAMPS dej dale earnhardt jr model dk2 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED, COLOR dk6 CONSOLE ROOF INTERIOR dl5 DECAL ROADSIDE SERVICE INFORMATION d58 SPOILER RR - DELETE fe4 SUSPENSION SYSTEM SPECIAL RIDE & HANDLING fr2 RATIO TRANSAXLE FINAL DRIVE 2.93 ip3 TRIM INTERIOR DESIGN (P3) jb9 BRAKE LIGHT WEIGHT, DISC/DISC jl9 BRAKE SYSTEM PWR, FRT & RR DISC, ANTILOCK, FRT & RR WHL ka1 HEATER SEAT, FRT k43 GENERATOR 102 AMP l67 ENGINE GAS, 6 CYL, 3.8L, MFI, V6, SUPERCHARGED mn7 TRANSMISSION AUTO 4 SPD, HMD, 4T65-E, HEAVY DUTY mx0 MERCHANDISED TRANS AUTO PROVISIONS, O/D ne1 CERTIFICATION EMISSION, GEOGRAPHICALLY RESTRICTED REGISTRATION FOR VEHICLES UP TO 14,000 LBS GVW (USE 2003 MDL YR ) np5 STEERING WHEEL LEATHER WRAPPED nu4 EMISSION SYSTEM CALIFORNIA LEV2 PLUS osh PLANT CODE OSHAWA, ONT, CANADA (TRK) pdg CONTROL SALES ITEM NO. 124 qs1 ????? qwm TIRE ALL P235/55R17-98W BW R/PE ST TL AL3 slm SALES PROCESSING STOCK ORDERS ua6 THEFT DETERENT SYS uc9 CLUSTER INST, OIL, COOL TEMP, TRIP ODOM, TACH, SUPER CHARGER BOOST ue1 COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 ug1 OPENER GARAGE DOOR, UNIVERSAL un0 RADIO AM/FM STEREO, SEEK/SCAN, CD, AUTO TONE, CLOCK, ETR u2k DIGITAL AUDIO SYSTEM S-BAND u68 DISPLAY DRIVER INFO CENTER
#35
I find this fascinating, because last month I bought a 2003 Monte that is a Sandy flood car and I've gone through a lot of the same stuff.
The car has only 19000 miles on it, which is why I bought it. I've done pretty much all you've done, but a lot more. Haven't gotten to the engine yet, but it seems to be siezed. Cylinder 5 was still full of water. I'm soaking all of the cylinders with PB blaster right now, while I do the rest of the car.
I had no mold anywhere in the car, but I pulled the seats and carpet and cleaned them thoroughly. Had the same problems with the seat tracks, but I managed to get them out just as you did by lifting the foam. The power seat racks are all one assembly, and not designed to be repaired, but I did some cutting to get them apart and repaired them.
I pulled the entire interior out of the car, cleaned out rust & corrosion and rebuilt it.
I've replaced the climate control assembly, blower motor, vent servos, headlight switch, blower motor resistor assembly and body control module. I rebuilt the instrument panel with new motors and blue LEDs. I also rebuild all of the switched with blue LEDs and added them to the climate control assembly.
I had to replace the electric door lock motor in the drivers door and the trunk.
I also had to get new power mirrors.
The sunrrof & trip computer work, but the temperature sensor under the hood must be bad.
I'm hoping to salvage the engine and plan to pull the heads this weekend to see if I can free the pistons.
I've put in a touch screen Pioneer stereo and relocated the OEM stereo to the trunk, so I can still used the setup stuff and get the chimes.
My wife thinks I'm nuts, but I've restored cars before, and I like the 2000-2005 Monte body style.
#36
You should go to the new member thread an say hi and introduce yourself and reprint this story of your rebuild. Many might not read it on this thread, nice to have another getting dirty member here on the forum. Red Nightmare and you might get along just fine...
#38
Update: Jen (Red Nightmare) purchased a complete engine wiring harness off eBay for a really good price. We received it today and replaced the old one. Everything seems to work now as you can see in this video...
We are happy with the results but it still needs some work.
#40
Mine is never getting sold, may sell jr 2091 (the one we are working on) Suspension is for jr 7(my own.) 2091 is going to be all stock except exhaust. Trying to keep everything as close to stock, similar date codes and oe parts.
