Baseline 06 Monte Carlo 3.9LT
I hooked up the G-Tech this morning, and went out to play. Temp was 44 degrees, the road was cold and bumpy, so wheelspin was a problem, even with TC on. Here's the results:
0-60 foot----------2.32
0-60 mph---------7.10
50-70 mph--------4.27
1/4 mile-----------15.3 @ 92.2 mph
I feel these are pretty good numbers (except 60 foot time)- the car is stock, had a full tank of gas, and a 265 pound driver. Anyone else have numbers for a 3.9?
TG
TG
RE: Baseline 06 Monte Carlo 3.9LT
Tom, thanks for posting. How many miles are on your Monte ?
Lose some gas & the times will be better : ) EnJoy!
Below is a MCF link to information on times for the 3.9.
Explore the forum & you will find a lot of infor.
[:-]Click below link[:-]
https://montecarloforum.com/m_16870/tm.htm
It's got 20K on it- I bought it used with about 18K. Since this was a baseline run, prior to modifications, I tried to control as many variables as possible: vehicle weight, section of road used,tire pressure, etc. Reason being that it's easier to duplicate conditions on subsequent test to see if there really is a performance increase from a given modification. I fugure I could knock off an easy half to three quarters of a second by dumping some weight ( less gas, lose the spare, have my 100 pound daughter drive, etc),air down the tires, remove air filter and other little tricks, but I like to test it in exactly the same trim as I drive it to work.
BTW, thanks for the link! I'm still learning my way around here.
TG
TG
uortiz714
05-04-2012 08:12 AM
Dovas Monte
02-01-2011 01:24 PM
team monte carlo ss
08-11-2008 06:02 PM
