2000 monte carlo ls wont start
First of all, welcome to the forum!!
OK, now tell us exactly what happens when you turn the key to start (noises, clicks, lights, etc)
it clicks the interior lights will flash until i hit the alarm but i have no luck with cranking or starting. itll just click and make a sound from the dashboard gauge and thats it
Make sure each battery terminal on the battery is cleaned, clean each battery cable connection at the battery, at the starter, and ground. Sounds like something is just not making a good connection. I know you said that you replaced the battery and starter but it could very well be corrosion up inside your battery cables causing this. But I would go clean all those areas I mentioned before you go spend any money.
