2000 monte carlo ls wont start
Old Jan 11, 2017 | 06:21 PM
Delondre Davon Stevenson's Avatar
Red face 2000 monte carlo ls wont start
What's up everybody I have a 2000 monte ls and it will not start for me. I have changed the spark plugs,ignition switch,battery, and starter. I really need help on what to do
Old Jan 11, 2017 | 06:27 PM
First of all, welcome to the forum!!
OK, now tell us exactly what happens when you turn the key to start (noises, clicks, lights, etc)
Old Jan 11, 2017 | 06:50 PM
it clicks the interior lights will flash until i hit the alarm but i have no luck with cranking or starting. itll just click and make a sound from the dashboard gauge and thats it
Old Jan 11, 2017 | 06:51 PM
Old Jan 11, 2017 | 07:19 PM
Make sure each battery terminal on the battery is cleaned, clean each battery cable connection at the battery, at the starter, and ground. Sounds like something is just not making a good connection. I know you said that you replaced the battery and starter but it could very well be corrosion up inside your battery cables causing this. But I would go clean all those areas I mentioned before you go spend any money.
Old Jan 25, 2017 | 06:39 PM
Brendocee55's Avatar
Wow looks like you already did the ignition switch, maybe it's a fueling problem?
Old Jan 25, 2017 | 07:17 PM
Default I
[QUOTE=Brendocee55;699664]Wow looks like you already did the ignition switch, maybe it's a fueling problem? I figured it out. my ac compressor locked up causing my car not to turn over
Old Jan 26, 2017 | 04:24 PM
Never heard of that being the problem for starting, good you got it figured out though
