Bad sensor? Low Brake fluid , Brake and Trac off alarms
Old 12-26-2012, 06:14 PM
Jerry Barao's Avatar
Default Bad sensor? Low Brake fluid , Brake and Trac off alarms
i'm hoping this is only a bad sensor , but after clipping a pothole i got all 3 of these warning lights at the same time : Low Brake Fluid, Brake and Trac Off.
i could see the brake and trac off lights only being a sensor, but the low brake fluid also is what i cant figure out ....any ideas?
thanks
Old 12-26-2012, 08:06 PM
Did you actually check the brake fluid and make sure it was still full? Sounds like an ABS wheel sensor or the wiring for it. If the wire gets disconnected it can make those warnig lights go on. I have also seen a bad battery make the ABS and brake warning light come on also. If you have an ABS problem, the traction control will not work until the ABS is fixed.
Old 12-26-2012, 08:10 PM
My low brake fluid light came on when I tugged on the connection underneath it. Check it, unplug/plug to see if goes away.
Old 12-26-2012, 08:35 PM
i was leaning towards it being the abs sensor....checked brake fluid and level was good. is an ABS sensor difficult to replace?
Old 01-05-2013, 03:33 PM
turns out it was the Brake Fluid level sensor.....nice easy $12 fix.
Old 01-12-2013, 07:54 AM
Default Low fluid sensor
Where was the sensor located?
matthew41
01-25-2015 11:22 AM
hotrodharley
11-15-2013 11:37 AM
hotrodharley
10-11-2013 07:13 AM
Monteimpala
03-08-2012 02:32 PM
heartbeat
01-14-2012 10:47 PM
Quick Reply: Bad sensor? Low Brake fluid , Brake and Trac off alarms
