Bad sensor? Low Brake fluid , Brake and Trac off alarms
Old Dec 26, 2012 | 06:14 PM
Jerry Barao's Avatar
Default Bad sensor? Low Brake fluid , Brake and Trac off alarms
i'm hoping this is only a bad sensor , but after clipping a pothole i got all 3 of these warning lights at the same time : Low Brake Fluid, Brake and Trac Off.
i could see the brake and trac off lights only being a sensor, but the low brake fluid also is what i cant figure out ....any ideas?
thanks
Old Dec 26, 2012 | 08:06 PM
seawolf18's Avatar
Did you actually check the brake fluid and make sure it was still full? Sounds like an ABS wheel sensor or the wiring for it. If the wire gets disconnected it can make those warnig lights go on. I have also seen a bad battery make the ABS and brake warning light come on also. If you have an ABS problem, the traction control will not work until the ABS is fixed.
Old Dec 26, 2012 | 08:10 PM
Jomao_o's Avatar
My low brake fluid light came on when I tugged on the connection underneath it. Check it, unplug/plug to see if goes away.
Old Dec 26, 2012 | 08:35 PM
i was leaning towards it being the abs sensor....checked brake fluid and level was good. is an ABS sensor difficult to replace?
Old Jan 5, 2013 | 03:33 PM
turns out it was the Brake Fluid level sensor.....nice easy $12 fix.
Old Jan 12, 2013 | 07:54 AM
Louis Kolakoff's Avatar
Default Low fluid sensor
Where was the sensor located?
matthew41
Jan 25, 2015 11:22 AM
hotrodharley
Nov 15, 2013 11:37 AM
hotrodharley
Oct 11, 2013 07:13 AM
Monteimpala
Mar 8, 2012 02:32 PM
heartbeat
Jan 14, 2012 10:47 PM
