7th Gen ('06-'07): Battery dead
Old 04-18-2020, 06:54 PM
FloridaSS's Avatar
Default Battery dead
Any opinions? Went to start the 06 SS after maybe a week of not driving it. No instrument lights, chimes and no power at all to the starter. I put the battery on charge until charger said it was full. Still no power on anything in the car. Voltage test on the battery by multimeter was about 2-3 volts. Vehicle wouldn't respond to a jump box either. Before this happened, there was a noise that sounded like it was coming from the dash area while driving. It sounded like some sort of electrical device turning off and on. The sound was maybe every 3-4 minutes and would last about 3-4 seconds. Battery was only a few months old.
Old 04-20-2020, 11:06 AM
Disconnect the battery from the car and then try charging. If it still does not charge up, you have a bad battery. Not uncommon to get a bad one.
Old 04-20-2020, 05:54 PM
X2. Recharge the battery, then load test it all completely off the car. If the battery is that new, it should still be under warranty.
Old 05-20-2020, 09:12 PM
I had a poor ground in the cab, on the aluminum under dash framing, causing the electrical system to continually look for a ground and run the battery down and kill it. Had two batteries go bad because of the poor ground, in five months
Old 05-21-2020, 10:34 AM
FloridaSS's Avatar
Well I had to have it towed to the dealership and they charged the battery, let the vehicle sit for a few days and it started up, drawing the proper power from the battery. No problems since. And the noise behind the dash is gone. Weird.
JeepGuy
09-28-2017 02:57 PM
96z34man
01-13-2017 01:41 AM
avendo
02-19-2015 05:30 AM
oconnomo
05-18-2013 10:28 AM
oaky812
06-02-2010 02:53 PM
Quick Reply: 7th Gen ('06-'07): Battery dead
