interior lights dim when headlights are on
I did check the dimmer switch. Someone told me it could be a module but I would have to go to the dealer because it also runs my odometer. It is all good with the daytime running lights. When it gets dark enough for the regular lights to come on, all interior lightd go dim. It's tough to watch the speed at night. I thought maybe there may be a sensor. Thanks.
Well if it's not the dimmer switch I'd be torn between a voltage issue like Boxman said or it's BCM trouble (the BCM controls basically everything electrical in these cars).
Was the car ever jump started?
