Trying to help my son
Old 12-27-2007, 01:57 PM
RockinRickus's Avatar
Default Trying to help my son
Hello All, I'm trying to help my son. He has a 96 M/C le.
question- Does this model have a Anti-theft system? (starter kill switch) if so any info, please.
The other day his car just quit, found no starter. Replaced new starter, with key nothing. Jumping starter gets it to entergize but will not turn over motor! Had new starter checked, it's ok. So back to square one.
Thanks Rick
Old 12-27-2007, 02:21 PM
Default RE: Trying to help my son
Hi Rick, your son is lucky to have a father to help him.
Your model has a Pass Key II System.
When you replaced the starter, was there any metal
partials around the teeth of the starter ?
If not, it could be a bad pass code key
(Clean key with mild dish soap, dry & try : )
Below are some links for infor ` Good Luck, `Space
The 1996 Monte Carlo is available in two models - LS and Z34 coupes. ... Scotchgard Fabric protection, Pass-Key II theft deterrent system, ...
www.intellichoice.com/reports/vehicleReport/vehi... - 15k
GM Vehicles:
Most GM vehicles are equipped with one of two different technologies for their factory anti-theft systems, the PassKey or the PassLock system.
PassKey System:
$30.00 Installed
This system began to be used in 1986 and is still used on some current models today. This system simply has a coded resistor embedded in the metal portion of the key, which sends a signal to the vehicle allowing the motor to crank. It's easy to determine if your vehicle is equipped with this system. Look at your ignition key and see if you have a black chip on the metal portion of the key. (refer to the picture below for reference) If your vehicle is equipped with the PassKey system, then an additional part is required in order for the motor to start by remote.
PassKeyIII System: $75.00 Installed
This system began to be used in 1997 and became widely used by 2000. This system simply has a coded transponder embedded in the plastic portion of the key, which sends a signal to the vehicle allowing the motor to start. It's easy to determine if your vehicle is equipped with this system. Look at your ignition key and see if PK3 is engraved on the on the metal by the plastic, then you have the PassKey III system. If your vehicle is equipped with the PassKey III system, then an additional part is required in order for the motor to start by remote.
[font="verdana, arial, helvetica, sans-serif"][color=#000000][size=4]PassLock System: $75.00 Installed
This system was introduced in 1995 on some vehicles and has progressively been used more and more, where it is found on a good majority of GM passenger vehicles. This system is standard on all 1998 and up GM trucks and SUVs. The PassLock system does not use the key pictured above. The best way to determine if your v
Old 12-27-2007, 02:30 PM
Dude you the man, I'll try all these. Thank You
Old 12-27-2007, 02:47 PM
space...u r the man lol
Old 12-27-2007, 05:34 PM
Your Welcome `Rick,
I sure hope it helps. Let us know `ok.
If it doesn't, post again and one of our expert may have
a solution.
Good Luck `Space
Old 12-27-2007, 05:39 PM
ORIGINAL: kweef
Jeremy, yeap-per's....I'm the
Space/Alien/Man
[8D]
I checked allmy equipment, & it's all there
& work'in : )
We just call it a Plug for are-charge
Old 12-27-2007, 07:17 PM
hey rick i know your new but please becareful how much you feed spaces ego.
We try to keep him in check . He is to good and makes the rest of us look bad
Space is our frend here!! if he cant tell you he will find a link ro the information for you. he is honestly a very good person.
still trying to figure out how he can put up with me and R.J. LOL
Old 12-27-2007, 07:40 PM
Taz is offline
ORIGINAL: mickey
That's right. Space is the man! [sm=icon_rofl.gif]
Sorry mickey, couldn't resist.
Bad Space! Making us all look bad. lol. [sm=joke.gif]
Just kidding spacedude.Don't appologize.
You're a good guy!
Old 12-28-2007, 12:00 AM
lol taz rnt u supposed to b tryin to control him along with mickey lol
Old 12-28-2007, 07:59 AM
ORIGINAL: kweef
Jeremy, just wait until you receive the high command position as
a MCF Moderator,& see `if you can control `Space.
There's a lot of `Space out there, & he spreads it everywhere
He does seem to leave a toilet paper trail : )
`It's so difficult to control a SpaceDriver, when he'sout ofcontrol : )
[align=center][/align]
Quick Reply: Trying to help my son
