Need Help Diagnosing New Problem
Old Jan 27, 2012 | 03:43 PM
Sparky-88's Avatar
Default Need Help Diagnosing New Problem
Ok Motorheads, hopefully someone can point me in the right direction for a new problem with our ’02 Monte.
Recently it’s started making a noise, seems to be from the front end, primarily upon deceleration. It sounds like what I would term a ‘gear noise’. Not very loud, but definitely not normally there. It is proportional to speed: as the car slows down, the noise goes down at the same pace. Seems like it is drivetrain related. I’ve checked all the fluids – oil, tranny, power steering, brake – all normal. The only thing I can see out of the ordinary is a little dripping that wasn’t there before. It looks like a very slow drip from somewhere near the front left (driver’s side). I haven’t identified the source. Dark fluid (darker than the engine oil), oily, smells like gear oil.
Engine has about 159K miles; tranny about 70K miles on it. Front end has never had any issues. Hubs are original.
Any thoughts?
Old Jan 27, 2012 | 03:50 PM
DRuben's Avatar
Any thoughts?
Cv axle, boot possibly leaking fluid. Thats my guess...
Old Jan 27, 2012 | 04:23 PM
nitehawkjcb's Avatar
Could be a wheel bearing going bad
Old Jan 27, 2012 | 04:36 PM
Sparky-88's Avatar
Thanks, guys. I'll crawl under it tomorrow and see if the CV axle boot is the source of the leak. And I need to look at my maintenance manual tonight to see how tough both of those jobs would be. Never had to mess with either yet.
Old Jan 27, 2012 | 06:46 PM
forgotten's Avatar
can you describe the sound any more? how does the coolant level look?
Old Jan 27, 2012 | 11:54 PM
tj4ndirish's Avatar
CV boot and bearings should be nice and easy. An hour on both sides for each job.
Old Jan 28, 2012 | 06:39 AM
Very possible it is a bearing, I put my walkthrough from last week in the 6th gen How-to
Old Jan 28, 2012 | 07:01 AM
SupplySgt's Avatar
I was thinking bearing as well. Good luck on finding out what's wrong.
Old Jan 28, 2012 | 11:45 PM
Sparky-88's Avatar
Thanks, guys. I had a look today and didn't see anything out of the ordinary. No leaks apparent from the axle boots. Since it's my wife's daily driver, I may get some diagnosing help early next week from a local shop.
Mike - I'll check out your write-up on the bearings.
Old Jan 31, 2012 | 08:49 AM
Sparky-88's Avatar
Shop says passenger side hub assembly / bearing is bad. Going to let them do this repair. I don't have the time to tackle it.
Also discovered that my lower intake gasket has a tiny leak. Crap... I replaced upper / lower intake manifold gaskets last year. But the lower gasket gave me significant grief; I had a hard time getting it seated properly. First time doing that job; learned a lot. So I suppose it's not a big surprise that it has a problem. I just dread doing it all over again. At least this time I know better what I'm doing. Ugh...
The only good news is that the lower gasket leak may be causing the P0171 code (Bank 1 too lean) that keeps popping up periodically. Would be nice to get rid of that once and for all.
