Monte Carlo Forums
Go Back   Monte Carlo Forum - Monte Carlo Enthusiast Forums > General Forums > General Tech
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Monte Carlo Forum - Monte Carlo Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Reply
LinkBack Thread Tools Search this Thread
Old 04-03-2010, 07:14 PM
Default DIY: Dual temp/heater control bulb replacement.
Mine is a 2002 SS with the dual temp control, not use what other years this may cover. You might want to first go to Radio Shack and get 12v bulbs, only $1.69 each. Otherwise you will be driving with your dash all apart. These are servicable if you are handy with a soldering iron.
1. Remove the dash. (You can use the DIY for radio installing).
2. Remove the temp control unit. (Only two screws, and uplug connections from back and take to a table).
3. Remove the three screws holding the black back, now pull apart.(Be carefull not to lose the three little springs).
4. Remove one screw holding the board to the control face.(Pull apart with the face of unit facing down, so you dont lose the buttons everwhere).
5. Now with the board in hand, locate brunt bulbs.
6. With iron desolder the bad bulb(s). (It is very helpfull if you have a solder sucker to remove the old solder).
7. Notice where the bulbs come through the back side of board, and use a knive and scrap alittle of the green coating around where the solder touches the board . This will expose alittle of the brass so the solder can ahear to the bulb lead and the brass lead on the board.
8. Not a very hard project at all. Just need to be handy with a soldering iron, and have a beer.
9. When done soldering, put everything back together.
10. Now you have just fixed you lights in your temp control for only $1.69 a bulb.
11. You can also order them online. Radio Shack PN: 272-1154
Have Fun,
Dave
Old 04-03-2010, 07:50 PM
Send a message via AIM to AwesomeSS
Thank you so much - I need to replace my passenger side temp control!
__________________
2003 Monte Carlo SS: Dynomax Exhaust, U Bend delete, K&N CAI, Graphics
2013 Ford Mustang MCA V-6: Sunroof, STB, Airaid CAI, Louvers, 35% Tint,
Mufflers delete, Bama Tune
Old 04-05-2010, 03:41 AM
No problem. Sure beats buying a new one. And no telling if the bulbs are going to blow on any used ones you buy off of Ebay. Just keep fixing your own.
Old 04-05-2010, 07:36 PM
Send a message via AIM to montecarlo01ss
i have to do this soon, did you change colors or keep it factory looking? should of taken pics of the board
__________________
'01 SS
Old 04-05-2010, 08:28 PM
I kept the factory colors, only because I wasnt sure if the bulbs were going to work. I may change the colors, and if I do I will photo the board. I thought of taking photos after I was installing the dash. It was getting late and I wanted it all together for the morning. Sorry about that. Next time I will take photos. But it really isn't that hard. Easy fix.
Old 11-20-2010, 04:51 PM
M.C.BOB's Avatar
I hate to bump a 4 year old thread, but I'm having some problems. I got all the way down to the climate control buttons/sliders and couldn't get the damn things off. I needed to get these off to get the bulbs switched out. So how do these come out???
__________________
~shake and bake~
2001 SS
Old 11-20-2010, 07:25 PM
You must be talking about the black rubber nubs on the sliders. They just pull straight off. They can be alittle tough, just be careful not to damage the sliders. Just pull off.
Old 11-22-2010, 11:57 PM
Quote:
Originally Posted by anyuta34 View Post
Do not eat 1 a heavy meal fore several hours before your class. yoga is best practiced on an empty stomach. Do new york escorts drink water, both before and after your practice in order to keep your new york asian escort body well hydrated.yoga for a beginner is the first step on a journey of ever new york asian escorts increasing self-awareness, a greater level of strength, endurance, and flexibility, and a nyc asian escorts deeper sense of peace. Have fun and enjoy everything along the way!Della Menechella is a yoga and fitness enthusiast who has been involved in fitness for over thirty years.tel : 212-655-5444
spammer, eat a heavy meal go outside my door so I can run your azz over, see ya, thanks for your garbage..
put the hammer down on this a-hole, please
Click the image to open in full size.
__________________
Chris #3 FOREVER
2006 3.9 LT3, CAI, dual Magnaflow mufflers and 4' tips.....
& a 1999 Z34 added to the family 8-19-11....
CODE: CPE1704TKS.......
Old 02-09-2012, 04:34 PM
Default 2004 dash board disassembly diagram
Are there any of these on this board? Again, I did a search with no results, so if there is one could someone post a link? Thanks.
Reply
Tags
03, 2003, 2006, bulb, carlo, controls, diy, dualtemp, heater, instrument, iron, monte, radio, replacement, shack
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
