Gauge install Help?
Old 01-09-2009, 11:48 AM
ChucksMonte's Avatar
Default Gauge install Help?
Hey,
Im going to install new gauges in the 04. There gonna be on the A-pillar. One is the AeroForce gauge which plugs right into the OBDII port. The others are trans temp and Volts. Trying to find the correct wires to tap into is a PITA and ZZP sells their "power drop harness". Only question i have is, where does the harness plug in?
https://www.zzperformance.com/grand_...&catid=108
If you got any other ideas or tips, that would be great!
Thanks,
Chuck
Old 01-09-2009, 06:40 PM
RocknSS04's Avatar
Default RE: Gauge install Help?
I have a trans temp and volt gauge in my dash. SW gauges. Not sure where the drop plugs into, but I'm guessing the fuse box. E-mail them, or even call them.
My tranny temp sensor is on top of the tranny, using the diagnostic port. 1/8 npt plug there.
Old 01-10-2009, 01:32 AM
I saw your tranny gauge install and that inspired me to do mine, but i got sidetracked and it got cold out. Im bored now so im gonna give it another shot. If i dont do something to make this car "mine" im gonna get really bored with it and trade it in, i dont really want to do that, i love this car!
Old 01-10-2009, 06:15 AM
RocknSS04's Avatar
My gauge cluster uses 1 1/2" SW gauges, but they are no longer made. I'd go with the A-pillar pod as you are. We have the Aeroforce gauges in LadyT's 07 Solstice GXP. You can't go wrong with the combo you are headed with! GREAT choice!
Old 01-10-2009, 12:42 PM
Thanks, I cant wait to get back on this project.
I emailed ZZP and am waiting for their reply.
Im going to use the 2 1/16 auto meter sport comp chevy gauges for the trans and volt.
http://www.jegs.com/p/Auto+Meter/990933/10002/-1
Old 01-12-2009, 12:41 PM
well just got a reply from Tim and he said :
I am not 100%, if it did, it usually plugs in under the dash on the Passenger side behind the glovebox.
i gotta go look at the car and see...
milehighz34
02-16-2012 04:32 PM
04chevyboy
01-29-2012 09:50 PM
Dbl_D718
02-19-2010 01:09 PM
musclecarfreak1235
09-18-2009 10:09 AM
2003supersport
11-21-2008 07:58 AM
Quick Reply: Gauge install Help?
