Info: Where to buy a used L67?
hey guys im looking to buy a used l67 and hd tranny,i seen milzy has both but they want $1300 for a 60-80k mile engine and $1200 for a used hd tranny,does anyone know of a place that sells decent used engines and transmissions for a good price? or would I be better off waiting for a donor car,where im from theres maybe a handful of supercharged montes and milzy also has an axle to make the swap easier instead of building my own for about $250 is that a good price or should I save my money and take a chance making my own?
You can also look for a used motor from a grand prix, they are basically the same, I think the 04 may be different, but up until then they are the same motor's, same with buick regals. Keep in mind you will still probably need a pcm from a monte, but you can usually find one on ebay
I would consider a good/used L67 and trans from a junk yard or donor car. It will cost you less and before putting the engine in, clean it up and put new gaskets all over it (you will still be money ahead).
As for the PCM, it does not have to be a Monte PCM. Heck, if you wanted a stock tune, I offer a PCM service and I probably have a Grand Prix L67 stock tune I could load on your existing PCM (but if you have the donor car, just pull the PCM from it).
It really comes down to how much you want to spend and how much work you want to make it all happen.
I figured up about what I could gather up from the bank and working and I would think $3000 would be a good goal for a motor,tranny,axle,and pcm and still have some left over for anything extra,like gaskets and maybe some rocker arms and pushrods,do yall think 3k is a good budget for this? I asked a shopped about it one time and they said id need $6000+ i just told them that they are crazy
Maniac I don't know much about these pcm's or tunes,im use to older model engines just straight motor and trans (no wires or computers) if i put an l67 in there and grab the pcm from the same car are there any tunes that will help as far as performance and running better? i don't want to drop tons of money into it but id like to make it last,ive been trying to find performance cooling parts like a radiator and things like that
They actually restrict more air-flow than they create. Complete waste of money.
yea i kinda figured,im looking for a good intake for the l67 but i heard the stock one was about as good as it gets but i just don't see it,the way mine is set up is it draws air right behind the driver headlight and i don't see how its getting that much air,i want to get some tubing and make my ow and run it closer to the ground to pick up more air and possibly colder,does anyone have any good suggestions on a good cai that actually makes a difference?
As for the PCM question, I got your PM. Let me know if that answered your questions.
