Mass Air Flow sensor bad?
Old 04-04-2013, 06:22 PM
03SSLE's Avatar
Originally Posted by STUMPMI
Just a Little FYI...
To dbl check to be sure its the MAF...
Unplug the MAF ...start it up and drive it...
If the problem disappears, Then its definately the MAF...(For testing purposes only) Not recommended to continue to drive with it unplugged...
If the problem persists...Then it has a whole other issue.
The only thing unplugging the MAF will do is cause the PCM to operate in open loop mode. Since open loop mode also querries the MAF (and it is unplugged) the lack of signal from it will force the PCM to load default tables for the AFR. Because of this the engine may seem to run a little better, but that does not mean that the MAF is bad. Besides, how is unplugging the MAF going to detect bad wiring if that's what is causing the problem?
Old 04-04-2013, 06:23 PM
TMoney's Avatar
So considering the results i got, it my MAF bad?
Old 04-04-2013, 06:28 PM
Since he did say he cleaned the MAF and shortly after the issue returned...
Would be a quick test to either qualify...or..Eliminate the MAF as the problem...
As far as a bad wire fix?.. The MAF test wont fix a wireing issue..
Thats why I also mentioned he may have a whole other issue...
I wasnt (didnt) go into the open loop explanation...Just trying to Disqualify or Qualify a Bad/Good MAF.
Old 04-04-2013, 07:04 PM
TMoney's Avatar
So do you think my mass air flow sensor is bad seeing the readings i got when i tested the MAF signal?
Old 04-04-2013, 07:29 PM
Question
Did you try un plugging the MAF? and do a test drive?
Did it resolve your issue?
Old 04-04-2013, 07:48 PM
03SSLE's Avatar
With the reading you got on the 'A' circuit I would check that wire (from the connector back to the power distribution center) for breaks, cracks or abrasion. Pay particular attention to tight bends and where the harness runs close to the body/frame. If the wire checks out okay then replace the sensor.
Old 04-04-2013, 07:57 PM
TMoney's Avatar
Ok will do. And I am doing the test drive tomorrow morning with the MAF unplugged
Old 04-04-2013, 08:10 PM
03SSLE's Avatar
Correction: I meant to say check the wire from the connector to the PCM, not the power distribution center. I was thinking about the power circuit when I typed that...
Old 04-17-2013, 05:25 PM
TMoney's Avatar
Replaced the MAF yesterday and turns out the MAF actually was bad. Issue I had before is gone and the OBD code is also gone
Old 04-17-2013, 07:10 PM
Glad to hear... It was a relatively simple fix..and Happy to hear...Your back up and running!
Were here to help...
Quick Reply: Mass Air Flow sensor bad?
