how to bleed air out of coolant
Old 09-14-2009, 04:28 PM
05SSMonteCarloSC's Avatar
Default how to bleed air out of coolant
How do I bleed the air out of my coolant system on an 05 SS MC ???
Old 09-14-2009, 04:34 PM
Below is a file link I had by Popular Mechanics. I hope it helps. Good Luck from `Space : )
http://www.popularmechanics.com/how_...e/1272246.html
Old 09-14-2009, 04:40 PM
Great help and fast reply....Thanks Space....
So is this right?? I run the car until warm, then I open the bleed screw on the gooseneck where the radiator hose connects to the top of the engine? (while the car is running) And then close it when fluid starts to come out?
Old 09-14-2009, 06:19 PM
i thought that the 05's or older had the actual valve to bleed the system?
Old 09-16-2009, 01:54 PM
ok so what I did is this. Everyday after I get home from work (after driving the car to and from work) I turned the heater on about 5 minutes before I got home. After I got home and shut off the car, I bleed the air out through the gooseneck and add antifreeze to the overflow container (to the half way mark). Did this for 3 days and now it seems like I have no more air in the system. The bleed screw only omits fluid now, no air. I no longer hear the sloshing under the passenger side dash board and the car doesn't run hot anymore. I couldn't find any other bleed screws other than the one on the gooseneck.
Old 09-16-2009, 02:06 PM
Gooseneck?
Whenever I bleed my system I use the bleeder screw on the top of the Thermostat housing. Takes 2 seconds, easy to reach.
Old 09-17-2009, 12:22 PM
yeah thats what I meant......
Old 09-17-2009, 12:34 PM
Gotcha. To me the gooseneck is a part of the overflow container :P
mattilus2121
02-26-2021 10:35 AM
Mueller
06-13-2014 10:40 AM
The_Maniac
05-07-2013 06:34 AM
06-29-2012 10:51 AM
jasper
04-14-2007 10:01 PM
Quick Reply: how to bleed air out of coolant
