1995 monte 3.4 v6 superchargeable?
Old Apr 30, 2011 | 10:15 AM
daniel's 95 monte's Avatar
Default 1995 monte 3.4 v6 superchargeable?
hey id like to know if it is possible to supercharge my 1995 monte carlo? it has a DOHC 3.4L v6 in it.
Thanks, Daniel
Old Apr 30, 2011 | 11:13 AM
zipper's Avatar
What I'm about to tell you isn't meant to offend, but will help you understand your situation. With that said, the 1995 model year is the WORSE year Monte to own. This is because the computer system is something inbetween OBD-I and OBD-II (dubbed OBD-1.5). There is really no practical way to tune the PCM because of that. If you want to spend the time and money to get a COMPLETE wiring harness from a 1996 or 1997 Z34, then that will help.
Next, there is no practical way to supercharge the 3.4 DOHC V6 (LQ1). However, it has been done:
The problem with that setup is that there were a few custom parts that were needed and the price of it was pretty expensive too IIRC, plus the hood had to be cut open since the supercharger stuck out of the hood about 4-5". If I were you I would probably sell your 95 Monte and if your heart is set on doing a crazy build with an LQ1 powered Monte then buy a 1997 Z34 (best year for the LQ1 Monte's) and then turbocharge it. In the end it will be cheaper, you'll make more power, and there will be fewer headaches.
Old Apr 30, 2011 | 12:06 PM
umm, thanks haha i know it may be junk but i got it for 150 dollors and im 16 so i truly didnt care lol.. i want power and idk if i want to buy a camaro or just see what i can do with my car. is a L67 swap possible?
Old Apr 30, 2011 | 12:30 PM
jwjones's Avatar
you could put any kind of motor you want into any car. The question is are you willing to put alot of money and work into it? Your looking at some major work. Even me, when I was taking the L36 out of my 2001 SS I wanted to get the L67, but that involved finding a L67 motor, and transmission, and a wiring harness and wiring harness's are a pain in the ***!
Word of advice, leave it the way it is. If you want to make it faster then spend $2000 on a turbo setup
Old Apr 30, 2011 | 12:38 PM
very true. i might do that then.
Old Apr 30, 2011 | 12:45 PM
zipper's Avatar
I didn't mean to make it sound like your Monte is junk, because it isn't. It's a Monte But, if you do any major modifications to a 1995 Monte (LS or Z34) you will have to completely replace your whole wiring system with an OBD-II wiring system. If you want to do an L67 swap, then I would find a 1998 or 1999 Monte Z34 in a junkyard and take out All of the wires from it in order to convert your Monte to OBD-II. It's hard work, but a couple people have done it. If you go turbo, you will have to convert it to OBD-II as well.
That's why I said 1995 is the worse year for Monte Carlo's. It's all because it has OBD-1.5. If it wasn't for that, you'd have a great car
Old Apr 30, 2011 | 01:15 PM
i think i will just find a junk 99 and do the L67 swap.. i need a project anyway and it sounds fun to me.. and trust me you saying what you said didnt affend me cause i think its not the best either..i just wanna swap it so it has a nice sound and i love the wind of superchargers.. about how much is the wiring harness gonna run me?
Old Apr 30, 2011 | 01:49 PM
zipper's Avatar
I'm not really sure how much the wiring would cost, but I would budget at least $200 for just the wiring. It will all depend on how much a junkyard will charge though. Just make sure you get everything, from the OBD-II port all the way to the PCM.
Old Apr 30, 2011 | 01:51 PM
yeah im pretty sure i know where i can find a car in a junk yard that they would only charge me like 300$ to take that has everything but the engine.
Old Apr 30, 2011 | 08:38 PM
nitehawkjcb's Avatar
Don't get a car from a junkyard just to put an L67 in it. There's no telling what has been cut out of a junked car.
