7th Gen ('06-'07): Wheel spacers
Ok so I need the longer studs for all 4 wheels.. The extended dorman AND ARP studs are not long enough. I get maybe 4 rotations onto the stud with the dorman and arp studs.. The 60mm thread length (ebay link) are the ones I need. Also, the entire hub/bearing assembly needs to be disassembled to change these studs..
Ill quote myself here..
Yea, thankfully the car came from california so there is no rust and they come out with just a few taps.. Made myself a nice little tool for the impact gun to pull the new studs into place. Cant get a hammer behind there.
Fun fact.. GM made replacement studs shorter than stock so when (if) a shop needs to replace them, they dont need to disassemble the hub.. I would think thats a safety hazard. Theyre short enough as it is..
Dont have enough info to do a real calculation to see how much safety factor it eats away, but I'd think that's the main reason they dont offer longer fasteners. You can only improve material so much before you need to go larger diameter to carry the load further out.
