wheel bearings
Old Jul 15, 2008 | 01:07 PM
modernmuscle86's Avatar
Default wheel bearings
my traction control light and abs light are on. i believe it is the front right wheel bearing that i causing this problem. does anyone know how to change the wheel hub? i just moved form ontario to alberta and i need to get an inspection done on my car. This needs to be fixed by friday or i will have to get it done at a shop. any help would be greatly appreciated.
Old Jul 23, 2008 | 05:14 PM
04 Intimidator's Avatar
Default RE: wheel bearings
Take the rim off. Remove the caliper, remove the rotor. You will see a large nut. Unscrew it and the hub will come off.
msnyder1112
Jan 16, 2012 11:09 AM
02montecarlo
Aug 24, 2010 03:06 PM
stealthregal
May 8, 2008 11:02 AM
thewhitestcarlouknow
Dec 19, 2007 08:32 PM
Bullitt4005
Sep 12, 2006 05:29 PM
