Wheel bearing issue??
Old Jan 30, 2011 | 11:09 AM
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
Question Wheel bearing issue??
Hey guys, sry its been so long since I have been on but 19 credits is kicking my butt right now lol.... Anywho, after this spring of replacing all suspension parts and lowering carmen, I was still getting a "clunking" noise from the back right corner, and I still dont know what it could be because I thought for sure it was the top mount rubber, but I guess not. So the other day my dad took his truck in for a similar noise and ended up being a bad wheel bearing.... I think I may have the same problem in the back right corner.... What you guys think?
Old Jan 30, 2011 | 11:20 AM
Cowboy6622's Avatar
Don't wheel bearings usually sound like a loud tire or something?
Old Jan 30, 2011 | 05:29 PM
Yes a loud humming noise, But if the bearings are bad enough there could be some clunking.
Old Jan 30, 2011 | 06:08 PM
mrl390's Avatar
If your wheel bearings are bad enough to clunk, you should be able to get some play out of the wheel with your hands. Jack it up and see if you can wiggle the wheel or not.
Old Jan 30, 2011 | 09:14 PM
Photobucket
Ok thanks guys, idk... it doesnt hum and the only time I hear it is when I go over a bump or something
Old Jan 31, 2011 | 08:37 AM
daves92camaro's Avatar
what kinda struts are you running...cuz im haveing the same issue with my kyb agxs
Old Jan 31, 2011 | 09:33 AM
Photobucket
Kyb's Gr-2s with the ssc lowering spring but the noise was happening before I put those on, which is why I switched everything out.
Old Jan 31, 2011 | 10:10 AM
hrm yeah i have ssc springs to..but if it was happening before...hrmm...mine started after a few thousand miles after the swap...def should look into the bearings
Old Feb 1, 2011 | 07:30 AM
Photobucket
Alright sounds good, I might just replace that back one cuz thats the only place its coming from and there is no more suspension parts to replace! lol thanks!
Old Feb 1, 2011 | 07:45 AM
Check everything in your suspension that has bushings
