upgrading
Old Apr 8, 2009 | 04:11 AM
Buttarays's Avatar
Question upgrading
Im thinking of getting new shocks, struts, and maybe even lowering my monte. I wanna know the best way to go about this without doing anything wrong to the car. My friend says that I shouldnt lower it because the front end of the car tends to hit when going up driveways. any suggestions??thanks
Old Apr 8, 2009 | 04:27 AM
Arrow Welcome
Hi Member: `Buttarays, & Welcome to the MCF
What year/model Monte Carlo do you have ?
How low do you want 2 `go ?
What size tires/rim's do you have, or do you plan on
putting on your Monte ?
What is your Budget $'s 4 Suspension change ?
Check out the Forum's Suspension Thread, and
check back to see what our expert tech member's
post on your Thread question ?
Look forward to your answers, and future posts.
Good Luck
Old Apr 8, 2009 | 08:05 AM
your front end most likely isn't actually hitting as you think. There is an air reflector a piece of plastic in the front of our cars that usually does some scraping, not actually the front bumper. I usually just try to pull out more sideways than straight on to prevent that.
But I would recommend doing KYB GR2 Struts, and SSC springs, and a set of anti-pogo washers. All found on ZZPerformance.com (under grand prix and then suspension/brake)
Old Apr 8, 2009 | 08:25 PM
04 Intimidator's Avatar
The only way to go for lowering (as in the best way)
Eibach Springs
http://www.3800performance.com/Merch...roduct_Count=9
KYB-AGX Struts
http://www.3800performance.com/Merch...roduct_Count=0
Old Apr 9, 2009 | 01:45 PM
Buttarays's Avatar
I have a torch red 03 monte carlo. I was thinking 1 inch drop. I would like to keep a budget of around $800, but if its a little more then I can stretch a little. The thing I am most worried about is hitting the front from dips on street or turning onto drive ways. But I also want the handeling performance. I notice if I am turning on a graded interchange/on ramp and there is a bump on it the car tends to seem as though the back end wants to fishtail.
Old Apr 9, 2009 | 01:56 PM
Buttarays's Avatar
p.ss I have the stock chrome 16's that came with it. I do plan on getting black 18's.
Old Apr 9, 2009 | 02:10 PM
04 intimidator's way is more expensive but nicer handling and fully adjustable.
my way will be a little cheaper but not as great of handling and not adjustable.
lowering your car is always going to change the way you drive with dips and inclines.
Old Apr 9, 2009 | 03:02 PM
montecarlo01ss's Avatar
id recommend the ssc springs over the eibachs, ive heard better reviews for them. plus the ssc springs from zzp are cheaper
Old Apr 9, 2009 | 11:49 PM
nemesis's Avatar
2009 Monte Of The Year
x2 for ssc springs. the ssc lower about 1.5". if you can find vogtland springs they suppose to be better i believe they lower about 1.4"
Old Apr 10, 2009 | 09:43 AM
RickAKATed10's Avatar
Photobucket
Just curious, not really planning to, but do these items also fit the 06-07 Monte's?
