TSW Tremblant Wheels
The rear wheel/tire combo would be 1.5" wider, which is exactly how much room there is available to bring the wheels to the edge of the wheel well opening...just filling up the space and not bringing it any closer to the suspension.
Also, be careful how close you're getting the edge of the tire to the body. It is one thing to take measurements with the car in a static position, but quite another when performing a hard turn (ie emergency maneuver, fast on-ramp, etc) while articulating the suspension (from bumps, potholes, road debris, etc). The tire contact patch will move laterally in relation to the wheel, and the whole wheel/hub assembly will also move as a result of deflection in the bushings.
I'm not trying to say that bringing the tire out 1.5" is dangerous for your car and this wheel and tire setup since I don't really know, just something to consider.
The V8 Monte Carlo has so much torque, I don't see how putting a slightly wider wheel/tire on the rear would make a noticeable difference....Now if I was putting a wider, heavier combo up front, that would be an issue.
Youve never driven anywhere hairy, have ya? With more weight in the front, youll have more TRACTION in the front. The point of wider rear tires is to keep from losing traction in the first place.meebbe grasp the english language and read the post before you talk @#$%.
I say we settle it with a race, if straight line ill lose. But if its on a curvy road, prepare to be OWNED, by me
Increasing traction in the rear only isn't going to help you go any faster through a corner- the front tires will still break loose first at the limit in a corner, and the car will still push into the corner.
To try and bring the car to a more 'neutral' balance, you'd ideally want the rear tires to be narrower than the fronts (again, we're specifically talking these cars). That would lower the grip available to the rear tires, and would bring the point where they break loose closer to the fronts- and would allow the car to rotate better.
GM actually proved this point in the GP GXP- virtually the same car as the OP- they run a narrower wheel/tire out back, and a wider wheel/tire up front to do just this.
I don't race the Monte, just cruise and commute, so any performance reduction (I don't believe there would be any), is irrelevant for me.
I've done this custom wheel thing a few times, Kids. Watch and learn...
Can't believe I haven't seen this one.
I think the TSW Tremblant would look good on yours Scott. I thought an 8.5" wide was pushing it but 9.5" wide!? If you can get offsets to position them in the right spot, like you said, then I don't see why not. The wider tire, with the outer sidewall sitting right at the fender lip, would look mean. I want to see this though, and I say that because I may do wheels at some point and it would be nice to see (and hear) how the wider wheels work, look, feel, etc.
I know you lowered your previous silver SS but this red one is at stock ride height currently, correct? Do you see yourself lowering this one at some point as well?
Sorry for the late replies, kids. I've not been on the site lately.
Until Chicago digs out of the 6 feet of snow we've received, I'm just sitting here waiting for spring.
I can't wait to get the setup installed. I always measure multiple times, I use a wheel/tire measuring calculator, and have used spacers extensively on many cars, so I've become pretty good at figuring offsets and such. I did have 18x9" Torq Thrust Ms on my '06 at one point, so I am certain this will work.
Matt - I do not plan on lowering this car. I did not like the ride on my lowered '06 as you know...
Income tax refund should be arriving tomorrow, so....
Well, like you, I'm waiting for spring as well. Looking forward to updates.
...as Spring slowly approaches, I am getting closer to ordering my wheels & tires. I have whittled the total cost down to $1700 for the complete set...
Pictures should be coming soon, but not until the snow has disappeared
Brendocee55
Jun 18, 2015 04:31 PM
7th Gen ('06-'07): 18 Inch wheels to 20 inch wheels issues.
SuperSport™
Apr 13, 2015 01:28 PM
