Tires Size for 1995 to 2007 Monte Carlo's.
Chevrolet Monte Carlo Tires Size for 1995 to 2007 Monte Carlo's.
Click below to see factory sizes
http://www.dragtimes.com/Chevrolet-M...s-m8-n461.html
click above link to view tire sizes
Click on above pic 2 connect/explore
Don't forget to check out our MCF Sponsor
for tires/wheels +
for tires/wheels +
Tire Maintenance Tips | Automobile Tire Maintenance | Tire Safty Tips ...
When you see these wear bars, the tire is worn out and it’s time to replace it. Inspect your tires frequently. Look for any stones, bits of glass, metal ...
www.ntb.com/InspectTires.aspx · Cached page
How to Inspect Your Tires For Wear And Problems | Garage | Reader's ...
By checking the condition of your tires you can diagnose problems early and make your tires last longer.
www.rd.com/how-to-inspect-your-tires-for-wear-and-problems/article46502.html · Cached page
How to Inspect Tires for Wear | eHow.com
It's impossible to prevent your tires from wearing down over time, but if you inspect them regularly, you can help prevent serious damage or a blowout. It's not enough to just ...
www.ehow.com/how_2214829_inspect-tires-wear.html · Cached page
Videos of How to inspect your tires ?
How to Inspect Your Car Tire
5min 0:42
How to Inspect Your Tires for Signs of Damage or Wear
5min 1:31
LiveMojo: How to Interpret Tire Wear
Hulu 1:27
She's got nice Rims...Wonder if they are 17's, 18's or ?
5min 0:42
5min 1:31
Hulu 1:27
Can anyone tell me how wide and tall a tire will fit on a 2007 SS with stock rims.
Stock tires are P235/50R x 18's. I know P245/45R x 18 will fit but can I go wider with the same ratios of 50 or 45? Has anyone put wider tires on their car?
Bumped Thread to Get Member's Attention.
2007 Chevrolet Monte Carlo Tires Size P235/50R18
Check out above link & also if none of our member's have the answer, I would contact or email sites like Tire Rack/Discount Tire or a good tire shop in your area.
They can be very helpful...Good Luck & let us know what you decide/get....
Sorry to thread jack, but i read up on your build. Very very impressive.
after reading as much as i can in the past 2 weeks since i joined, (and there is a mountain range of knowledge and experience here) i've come to the conclusion the best time to do plan wheels and tires is when changing the suspension (and brakes).
first off i like the mc the way it is, stock, just fine. i could live with it real easy.
the changes i want to make are what i want to call subtle.
drop the front with new struts and coil springs - i don't think i'm in the coil over market.
new struts and coils in back.
thinking of kyb agx strust as a point of reference.
strut tower braces front and rear
bigger (solid) sway bars front and rear
dog bones
the anti pogo stick thing
i'm considering control and trailing arms but i might be taking things too far.
i like the way it goes on the highway when i have to travel, but i really love the well paved curvy back roads all around the horse parks outside town.
i was at my peak with torque wrenches in the 70's when wheel and tire options were simple. different sized cragars and eagle gts front and rear.
im probably way off and the search would be endless. one idea i have is 18 inch 245/45 zr18 on front and fatter 18s in the back with the same style but wider / offset rear wheels.
all i'm running into is "you cant put ANY wheels on your 2004 monte carlo ss"
i don't plan on new wheels and tires till spring but the way my luck goes nothing will work other than the stock geometry.
i dont know enough about the traction control and other computer integration to make this all work.
any comments or pointing to already-posted-material would be appreciated.
well maybe not from owners of horse parks as i whiz past their high dollar horses
dog bones
