Summit and ZZP sway bars
Old Mar 21, 2010 | 01:36 PM
I know my 05 SS did not come with a front STB, but my 03 did from the factory. I don't know if GM was trying to save money on the supercharged models because they gave the supercharged models upgraded suspension and trans so maybe they thought it wasn't necessary.
Old Mar 23, 2010 | 01:15 AM
#2726's Avatar
So for those of us with NASCAR SS Monte's, we don't need to focus on suspension upgrades?? I know the suspension is TONS better than the LS I previously had, a lot stiffer suspension... It's great!
Old Mar 23, 2010 | 11:47 AM
Donutboy97's Avatar
Monte Of The Month - April 2010 & Sep
here is the info on installing the front sway. IT's a pain in that it's difficult to get it in and out. The rear is way easier. I have the GMPP fronts and the CompG rear and love it.
http://www.grandprix.net/upgrades/frontswaybar.html
Old Mar 23, 2010 | 08:16 PM
montes my python's Avatar
Check the build sheet on the drivers door, look for the suspension code, it will be FE2 or FE4, the FE4 already has the same bars front and rear as the GMPP and ZZP bar, It also comes with the better trailing links, some came with a front STB. If you have the FE2 just get the kit from GMPP and it comes with everything you'll need, large improvement in handling.
The front bar is easy to change if you remove the 2 rear subframe mount bolts and lower it a couple of inches with a jack, just be careful and don't go too far, the whole job takes about 30 minutes
Old Apr 12, 2010 | 10:36 PM
Joe Thomas's Avatar
My friend has a 2002 Regal with a supercharger. His suspension code is FE3. I guess GM doesn't want those Buicks to ride too hard.
BTW, I installed a GMPP kit in my Monte. For the front, just disconnect the passenger side tie rod so you can turn the wheel out of the way and the bar will slip right in.
Old Apr 17, 2010 | 11:22 AM
puffins629's Avatar
Those look to be the same but i am a fan of zzp no matter what the price it is really up to you. I know that they can be really difficult to put in if you dont have the right tools and everything depends on how rusty and coroded everything is. It shouldnt take more than a couple hours if you have problems. I know they improve handeling alot i have installed 2 sets on a couple grand prixs and they are well worth it.
blackbeauty89
Dec 1, 2011 10:35 AM
montecarlocrazy
Dec 5, 2009 12:23 AM
3900Hero
Nov 30, 2008 02:28 PM
big green dog
Jan 7, 2006 11:56 PM
rchurch
Aug 19, 2005 05:36 PM
