Rotors and Brakes
Old Mar 13, 2013 | 09:57 PM
Jethro's Avatar
Default Rotors and Brakes
Hey guys, it is time for me to do a rotor and brake change out job. Previously I have always used the regular smooth surfaced rotors and metallic brakes, but now I am considering going with drilled or slotted rotors and ceramic brakes.
What kind of difference should I see between the drilled and slotted rotors vs regular smoothed surface rotors? Do they wear down the brake pads unevenly since the entire rotor a flat surface? (the slots and then the drilled holes in the rotor is what I mean by not a flat surface.)
What should I expect performance wise from the ceramic brakes? Other than a smoother stop is there any other benefit?
Any thoughts on best rotors and brakes to go with? Trying to keep this 175-. Found a set front and back ceramic brake pads and 4 drilled and slotted rotors for my 2000 MC LS 3.4L for a price of 161.
Thanks ahead for your time!
Cody
Old Mar 14, 2013 | 08:05 AM
I'm a fan of just getting high quality blank rotors, meaning no cuts, dimples, holes, grooves, etc. I like Centric Performance
Ceramic brakes will be quieter, but can be dustier.
Old Mar 14, 2013 | 10:58 AM
Jethro's Avatar
Alright, so what would be best to put on my car? Just premium blank rotors and regular metallic brakes?
Old Mar 14, 2013 | 11:04 AM
I got the drilled and slotted with ceramic. really i have not noticed any extra stopping power with the drilled and sloted over stock... about the same performance but i like the apperance better
Old Mar 14, 2013 | 11:19 AM
Jethro's Avatar
Alright, thanks for the input! I will just go with the blank premium rotors then. They are a bit cheaper for me!
Thanks for the info Chibi as well!
Is there a way to fight the dust ceramic leaves behind? I rotate my tires just about every other month. If I take compressed air and blow it out would it help it at all? Or is the brake dust not that significant of a problem to worry about it?
Old Mar 14, 2013 | 01:15 PM
Just know that if you have nice rims, you'll be cleaning them more most likely haha.
Ceramic is quieter and stops a little better, also takes better to a little heat. Ceramic is definitely worth it, it's just a little dustier
Old Mar 14, 2013 | 02:15 PM
03SSLE's Avatar
If you really want to see an improvement in braking replace the rubber brake lines with braided stainless. Even brand new rubber hoses flex and absorb energy. Stainless covered PTFE hoses won't flex and allow more energy to reach the caliper.
Old Mar 14, 2013 | 03:07 PM
I have been seriously thinking about this. Maybe next season I am already putting big bucks in the Deuce for the Monte Nats this year so far i have spent about $1k and have to spend about $1.5 k more but she will be da Lady in Red 4-sure when I get done
Old Mar 14, 2013 | 04:44 PM
Jethro's Avatar
I have the stock rims from 2000 lol. So I am not too worried about it. I get a car wash once a week so. Will have pics up of my car this weekend, sunroof getting replaced today then can wash it and get pics up! The stock rims are in pretty good shape for being a 2000 really. But I got ceramic ones, ceramc brakes for front and back and then callahan premium rotors for front and back all for $125.
I will definitely remember that for when I am doing my suspension mods! Thanks!
Old Mar 14, 2013 | 08:05 PM
If your doing a full brake job it is a good time to paint the calipers if you haven't already. That way if you get new rims you'll be all set.
