Rim restore
Old May 26, 2016 | 11:30 PM
Awoodsr's Avatar
Default Rim restore
I'm l[IMG][/IMG]ooking to restore my stock rims
Old Jul 20, 2016 | 09:51 AM
Lawhorje's Avatar
Same here. Any ideas?
Old Jul 20, 2016 | 11:17 AM
Awoodsr's Avatar
Default Rim restore
Hey I just sprayed plasti dip over them turned out nice
Old Jul 20, 2016 | 11:44 AM
ohara's Avatar
Circa 1850 furniture stripper will remove the remaining coating that is on the rims, then get a tube of autosol and polish the metal. When done they will look like chrome, but it will take some work to get them to that point, but totally worth it, used to do this on my Harley's back in the day as it was cheaper than buying the chrome parts and had a similar effect on the overall look of the bike. If you want you can also spray some clear coat over them once they are polished up so the shine and luster will hold.
Old Jul 20, 2016 | 01:28 PM
Smile
I have been using acetone or finger nail polish remover on the wheels and remove the clear coat. Then I polish them up with a fine sand paper. fine grit 600, or 800 to clear the corrosion. test it first so you don't mar the finish. You can also use a polishing ball. Check with AutoGeek.com to see what they recommend. Sometimes you can find an old wheel to use as a test for the restoration and then when you get the results you want, you can go to the real thing.
