Rim cleaning issues
Old Jun 30, 2012 | 02:20 PM
blackmonte02's Avatar
Default Rim cleaning issues
I have been having some problems maintaining the shine of my rims after polishing. They become dull and have white residue from something on them after a month or so. Any suggestions on a fix or an excellent rim sealant?
Old Jun 30, 2012 | 07:26 PM
What do you use to clean them now? Members have had a lot of luck with the Mothers ball.
Old Jul 1, 2012 | 11:49 AM
I polish them with mothers mag and aluminum polish and i clean them with Flash Brown Royal or basically any meguiars or mothers rim cleaning product
Old Jul 1, 2012 | 12:31 PM
03SSLE's Avatar
It sounds like the wheels are oxidizing because they are not clear coated. After cleaning them try putting a coat of wax on them and see if that helps.
Edit: I've never tried this stuff, but it might be worth checking into also:
http://www.eagleone.com/keep-clean-wheel-protector
Old Jul 1, 2012 | 04:19 PM
Ok thanks for the advice. I will try a higher grade wax and see if that does the trick. Have you had good luck with eagle 1 because i bought the interior cleaner and i wasnt satisfied...it could be personal taste also.
Old Jul 1, 2012 | 05:01 PM
03SSLE's Avatar
I've never used a spray on wheel protectant so I don't know if or how well it will work. I wax my wheels, but they are chrome plated so I'm not battling oxidation. If you aren't fond of Eagle's products you may want to do a search and see if any other companies offer a similar wheel protection product.
Old Jul 1, 2012 | 05:30 PM
01 Monte SS's Avatar
I use nothing but White Diamond on my polished stuff! Claims to seal but idk for sure. Go ahead and call me crazy but after using this polish I used NXT2.0 (a "wax", actually more so a sealant than a wax) and have had no issues with dulling or surface rust. Stuff seems expensive but WARNING it goes a long ways! I do all of the stuff in my engine bay with a few drops!
Here are the areas I use it on..
Old Jul 1, 2012 | 05:45 PM
Ok i might have to try it. Cant see if it works until you try it! Yea i have polished aluminum so its kind of a pain in the *** sometimes.
Old Jul 2, 2012 | 07:17 PM
Ok i tried polishing my rims and when im done there are little spots all over...will those come out afteri put clear coat and wax on it?
Old Jul 2, 2012 | 07:19 PM
Might just need to polish a little more.
I spent about 1.25 hours PER rim.
