Rear hub stuck
Old Mar 12, 2011 | 06:40 PM
RAD R0b's Avatar
Default Rear hub stuck
The brakes, caliper and rotor are removed. the hub screws are off. abs has been disconnected. the E-brake actuator bracket is off. The problem is: I do not know how to remove the e brake assembly around the hub, I know i need to beat on the hub to get it off but I am afraid to hit the parking brake assemly. is there a way to remove the parking brake assembly without taking off the hub first? HELP PLEEEEASE!!!!!!
Old Mar 24, 2011 | 06:35 PM
farmerjg's Avatar
Did you get this taken care of? Are you just asking about removing the parking brake shoe?
Old Mar 25, 2011 | 09:01 AM
I've never had to take a rear hub off of a rear-disc equipped car.... But when I've taken front hubs off, I've had to use a air hammer (those are pressed in so tight just beating it out with a hammer/sledge does not work well).
Old Mar 28, 2011 | 08:01 AM
RAD R0b's Avatar
Hey, Thanks for the responses. turns out... the shoe just slides off of the actuator. I thought it was all one piece, wrong. in retrospect, had i not been so frustrated that probably would have been pretty clear. Once its off of the actuator it moves out of the way and the hub is wide open for pounding. It took awhile but after a good 20-30 mins of beating the crap out of it, the hub fell right off.
2002 SS
Mar 10, 2014 09:21 AM
silveradoman298
Aug 12, 2013 12:02 PM
uptownfam
Nov 23, 2010 05:04 PM
lade03SS
Feb 10, 2010 03:44 PM
