Rack and Pinion problems. Please read!!
Old Feb 6, 2006 | 11:00 AM
GR8MONTE's Avatar
Default Rack and Pinion problems. Please read!!
I posted this on another forum with no help so I am trying here :-)
I have a 97 Monte Carlo and just very recently replaced the inner tie rod on the drivers side. Before I replaced there was no leak from the rack. Now I am pretty sure it is leaking because I can see fluid drip off the tie rod boot. Did I inadvertently mess up the rack while replacing the inner rod? It did not take a lot of torque to get the old one off.
What is my course of action to fix this leak if it is the rack and what happens if I let it go for awhile?
Please help. Thanks
**** Just found out that there was a recall on 97 Monte Carlo's for "Power Steering Gear Lower Pinion Bearing Separation". If this occured, would it cause my leaking problem as stated above? Can anybody help? *****
mperko86
Apr 2, 2010 11:12 AM
2000_BLACK_SS
Jun 1, 2009 07:35 PM
zk6216
May 16, 2008 03:35 PM
White05LT
Mar 17, 2008 11:04 PM
GR8MONTE
Feb 8, 2006 12:32 AM
