oewheelsllc.com question
Old Mar 28, 2011 | 12:58 PM
joe053068's Avatar
I'd be interested on how they look. I was looking at ordering a set from there as well.
Old Mar 28, 2011 | 08:53 PM
70monte1's Avatar
They are due to arrive tomorrow so I will give my impressions and take some pictures when I get a chance.
Old Mar 29, 2011 | 06:51 PM
70monte1's Avatar
Well, I received my wheels today. They are pretty nice but not perfect. They have some imperfections on the finish but I'm not that concerned about it considering they are going to get imperfections just from being on the car.
The one big difference between the factory wheels and the replica's is that the silver part on the face of the wheels have real fine machining lines compared to the polished silver parts on the factory wheels. My factory chevy truck rims have these same type of fine lines. At a distance you wouldn't be able to notice the difference and people who have never seen the factory finish would never know either.
The wheels are made in China and come with new valve stems, stem caps, and a blank black center cap. The wheel design looks to be identical to the factory wheels.
For the price, I'm happy with the wheels but the finish could be a little better. I guess to a point, you get what you pay for. I examined my factory wheels a little closer and there is also imperfections to the finish that is not caused by everyday use such as dirt in the black painted parts. For anyone thinking of getting these, don't expect them to be perfect. Here are a couple of pictures. I took one trying to capture the fine lines but I doubt you can see them.
Old Mar 29, 2011 | 07:06 PM
thanks for the info, I'm still debating on what freaking wheels I want.... this is harder than trying to figure out a name for my daughter when she was born!
Old Mar 30, 2011 | 05:26 PM
70monte1's Avatar
Well, I got the wheels mounted today and they look pretty good, actually better than what my factory wheels were looking like. My factory wheels were made in the US and had some numbers on the inside of the rim. I don't know if they were part numbers or what.
The car seems to run smoother with the new rims. My "Low Tire Pressure" message came on soon after I left the tire shop. I stopped at the next gas station and checked the pressures in all tires and they were all at 35psi so I don't know why the message came up. I reset it and hopefully the message stays off.
Wayne
Old Mar 30, 2011 | 05:47 PM
Because the tires were changed it was probably tripped.
Old Mar 30, 2011 | 09:26 PM
70monte1's Avatar
How do these sensors actually work. Don't they have something to do with the ABS sensors? How do they measure if the tire is low? Thanks.
Wayne
Old Mar 30, 2011 | 09:36 PM
JAFO's Avatar
Wayne
Believe the way it's set up on pre-06 Monte is that one corner has to be "lower" then the other three. If memory serves correctly it's quite a big difference 10 pounds or so to set it off. I'm sure if I'm mistaken someone else will be along shortly to set me straight. The 06 & 07 actually have sensors on the valve stems that measure pressure and sends them back to the computer.
Old Mar 31, 2011 | 05:17 AM
70monte1's Avatar
I looked in my owner's manual and it said if there was a twelve pound difference the message would come up but the only other time this message showed up, the lowest tire was only about five pounds different from the others though it was slightly lower than the recommended 30 psi. Thanks.
Wayne
