O~O Tire Rotation + Air Pressure O~O
Tire </CUFONTEXT></CUFON><CUFON style="WIDTH: 93px; HEIGHT: 22px" class="cufon cufon-canvas" alt="Rotation"><CANVAS style="WIDTH: 108px; HEIGHT: 23px; TOP: 0px; LEFT: -2px" width="108" height="23"></CANVAS><CUFONTEXT>Rotation
http://www.acura.com/images/faq-tire.jpg</CUFONTEXT></CUFON> <!-- --> <!-- .clear -->by Pat Goss Everyone knows to keep their tires rotated, but like most things, there’s a right way and a wrong way. Pat Goss has advice on how often, and in what pattern tires should be rotated. Have you checked the price of tires recently? They are expensive. So, how would you like to get twice as much ware out of the tires? Well, in most cases you can. That’s by properly rotating the tires on your car. Now, contrary to what you might hear – proper rotation means that at least two of the tires on your car have to turn in the opposite direction, which means they have to get on the other side of the car. But before we get in how you do that, why is that so important? Well, if we look at this tire, we can see these blocks of rubber; now, as this tire rotates down the road, this edge of this block of rubber hits the road first and it pushes the rubber down and the back edge of it out. Well, that means that the back edge of that block of rubber gets more ware than the front edge. Well, over a period of time, the tire is going to get noisy and you’re going to get an uneven ware pattern along the edge of the tire. To prevent that, you simply turn it in the opposite direction. http://www.motorweek.org/images/goss...125_goss_3.jpgOk, so, what is the proper tire rotation? Well, we’re dealing with a front-wheel drive car so what we’re going to do is, we’re going to take the right front and go straight back to the right rear. Left front is going to go to the left rear; then, the right rear is going to left front and the left rear is going to the right front. We’re ‘x-ing’ the tires that are going on the drive wheel. Now, if you have a rear-wheel drive car, you would reverse that procedure. Now, by getting these tires to rotate in the opposite direction, well, you’re going to even out the tire ware and get longer tire life. Now, a couple things you should be aware of – you’re going to do this yourself, get yourself a tire crayon and mark the position of the tires on the inside and where you’re going to put them before you take them off so you don’t get ‘em mixed up – that’s what we do in the repair shop. And the second thing is, and this is especially true if you take your car to a repair shop to have the tires rotated :eek: – always use a torque wrench to reinstall the wheels :). You see, torque wrenches will prevent warped brake rotors. Air impact wrenches almost always guarantee warped brake rotors :mad:. So this can save you a lot of time, a lot of money $:) and a lot of aggravation, just like the tire rotation can give you a lot longer tire life. :thumbsup: http://www.clipartguide.com/_named_c...part_image.jpg Hi Member's, how often are you Rotating your Tires ? Are you doing it different then above :rolleyes::confused: Post why `if you do ? |
<HEADER class=header>How to Calculate Tire Air Pressure
<!-- google_ad_section_end() --></HEADER><FOOTER class=footer><FOOTER class="AuthorProfileWrap footer">XJered Slusher <!-- google_ad_section_start() -->Tires that are over- or under-inflated are unsafe, and wear out easier than tires kept at their proper pressure. You've probably seen advice about keeping your tires inflated to the proper psi (pounds per square inch). However, changes in temperature can make it difficult to gauge the optimal psi for your tires, since tire pressure fluctuates with changes in outside temperatures. Related Searches:<!-- google_ad_section_end() --><SECTION class="Module body FLC"><DL class=difficulty><DT>Difficulty:</DT><DD>Moderately Easy</DD></DL>Instructions <SECTION><!-- google_ad_section_start() --><SECTION class=thingsYouNeed> <HEADER>Things You'll Need </HEADER>
</SECTION>
I always have to rotate front to back & keep em on the same side sence all my tires are directional tires :thumbsup:
Hi Mike,
Thanks for your post & pointing that out... I 4-got all about that & I think Pat Goss did 2 ~> :rotfl: How often do you rotate ? Do you torque your wheels ? Do you have them High speed balanced ? Are directional tires more Expensive ? |
I rotate every other oil change & no :thumbsdown: i prob should & yup i balance all my own tires in my shop :thumbsup: & honestly idk if they cost more or not just happend to end up with em on all my cars lol
I rotate every oil change. Properly TQ everything to my 100ft/lbs. ESPECIALLY after I have to take the Monte into a shop and I know they removed the wheel.
I rotate my tires every time I put my car in gear. :wtf:
Seriously, I rotate them approx. every 6,000 miles and check tire pressure weekly. |
I been checking my pressure every week because the temperature changes we have had keeps giving me low tires. I rotate twice a year and give the rims a nice deep cleaning and then tighten them down with the torque wrench. I also like to put a light film of grease in the studs and around the hub to keep things from getting stuck. I started doing this on my old truck because it would always rust up.
Do you know if the grease affects the TQ rating?
@Chibi: YES.
