new wheels an tires
Old Nov 26, 2009 | 08:47 AM
OD_85'305_SS's Avatar
Cool new wheels an tires
does anybody know whats the biggest wheel and tire combo i can fit under my 85 monte ss
i kinda want to put c4 wheels on it .......would they work bolt pattern wise ?
also if anybody knows if the wheels off the mid 90's impalas would work/fit?
or if anybody has any 86 and up ss wheels they want to get rid of
or some i-roc wheels
please let me know
Old Nov 26, 2009 | 09:47 AM
Budsjlm's Avatar
bolt patern from corvette,malibu,monte,elcomino,firebird,camaro, are all 5x4.75 the c4 rims will work but you will more than likly need spacers for the rear so it will not rub
Old Nov 26, 2009 | 02:11 PM
TheMonteMan's Avatar
i dont think a setup like that would work. i think all of the vettes ran real deep backspacing and depending on how fat of a tire you want to run your probably going to rub on the inside near the frame. i dont know what kinda diameter your looking to run but on a 15x8" rim the widest ive fit without rubbing was 275/60/15s with 3.75 or 4in backspacing either will work. your lookin at 28in tall overall diameter and about 11in wide at the buldge. if you stay within those dimensions and keep the backspacing in the 3.75 to 4in range u should be able to fit a ton of wheel tire combos.
Old Dec 2, 2009 | 04:58 PM
LT1 Monte's Avatar
From: Colocated I work and live in Montgomery AL working for Air Force and have a house with my toys in TN
I was hoping to run 275/50/15's but from your experience it sounds like that will hit. I wanted to have some serious meat, but I can simply use a set of slicks at track...
Glad to have read you post probably saved me some real grief. The slicks I have are I think 8" wide and 26" tall so I think they will fit with no problems.
Thanks
Old Dec 11, 2009 | 04:55 PM
ive tried 275 50 but that was on a 8.5 with 3.5 backspacing. it was a hoosier quicktime tire and it rubbed if i had weight in the rear. i trimmed the rear wells and they would still rub on the quarters but that car had a sloppy spring and shock set up. if it would have had 8" wheels on it it would have fit. heres the pick of the car with the old wheels they were 15x8 with 3.75 with 275/60/15. the new set up has 3.50 neither rub i perfer the 3.75 just think it makes the wheel look fatter. i like running the 28" tire cause with the 3.73s and the 700 first gear and the torque of the 406 its tough to get off the line so a little bit of tire helps kill the gearing a little. and when i had the 350 trans with no motor work it was a nightmare with a short tire.
wutwut25
Jan 25, 2013 09:24 AM
jeffsmonte
Oct 15, 2011 01:43 PM
03SSLE
Sep 30, 2011 08:11 PM
Teacher
Mar 28, 2010 04:54 PM
