Lug Stud Help
Old Apr 10, 2019 | 04:43 PM
Default Lug Stud Help
Ok so if these fit my 05 monte... They do, ive triple checked..
https://www.dormanproducts.com/p-789...rigin=oesearch
Then so would these, correct?
https://www.ebay.com/itm/10x-Syun-60...-/182633577538
Im 99.9 percent sure ive correctly matched the knurl size.. And shoulder length. Pls tell me im right..?
Old Apr 11, 2019 | 09:03 AM
Jeffs02rwdSS's Avatar
Yes ,you are correct they will fit in the hub . The only issue you might run into is the length. Nothing exciting but you might have too loosen the hub from the spindle to get the longer studs installed. Good luck
Old Apr 11, 2019 | 10:43 AM
If you're looking for extended studs, you should take a look at ARP. I dunno about trusting some random company with a safety critical item like that.
Old Apr 11, 2019 | 04:16 PM
9mm difference in length might stop a capped nut from tightening a wheel
Also, Dorman measures the length in the entire bolt, end-to-end. That ebay listing is measuring 60mm on the thread alone. Those studs are going to be pretty long
2002 SS
Mar 10, 2014 09:21 AM
Jordanshedd5
Nov 18, 2010 12:11 PM
Aobclanlead
Jun 15, 2010 01:09 AM
chevyboy989
Feb 4, 2009 02:20 AM
Martelli
Jun 25, 2008 04:00 PM
