Info on Wheels!!
Old Jan 29, 2011 | 03:45 PM
ar3em11's Avatar
5 Year Member1 Year Member
Default Info on Wheels!!
Im looking at a set of wheels on tire rack, they offer the same wheel with 2 different backspacing's. One is 5.98" and the other is 6.02". Is there a big difference in the 2. Which would be better for me, or does it not matter?
Old Feb 5, 2011 | 07:42 AM
TaylorMutts's Avatar
What is the wheel width? For the stock 17 x 6.5" wheel, the offset is 40 (equals backspace of 5.3"). If you are going with a 7.5" wide wheel, that same offset would be 5.8" backspace. Any more backspace than the 5.8" (on a 7.5" wide wheel) could cause potentially some clearance issues with the suspension. I have no experience with that combo on a Monte, so can't say for sure it will cause clearance issues. Personally, I would stick with the same offset (40) regardless of wheel width.
Old Feb 5, 2011 | 08:17 PM
ar3em11's Avatar
both are 18x8 with an offset of 38 on both!
Brendocee55
Jun 18, 2015 04:31 PM
SuperSport™
Apr 13, 2015 01:28 PM
davidk67
May 10, 2012 09:21 AM
86ssls1
Jan 4, 2005 11:10 PM
