i want new rims
Old Sep 15, 2007 | 08:52 PM
KickAss81monte's Avatar
Default i want new rims
can someone suggest some rim sizes for my 1981 monte carlo. preferebly 15 or 16 but idk about width. i know my front ones are very skinny and the back ones are wide, lol and thats how i want it. also, anyone know some good looking knock off cragars or torque thrusts? thanks
Old Oct 10, 2007 | 07:41 PM
wheelguy's Avatar
Default RE: i want new rims
If you like the wider in the back look you can go 15 x 6 up front & 15 x 8 or 10 in the back. I know Carlisle in CA makes the Cragar SS in those sizes but not positive on the American Racing one. If you end up getting one of these two styles I would get the Torque Thrust because it is an all aluminum wheel & the SS is a composite so the barrels will rust.
Old Oct 10, 2007 | 08:12 PM
thanks, know anything about the backspacing??
Old Oct 10, 2007 | 08:55 PM
wheelguy's Avatar
Sure do, any size or style in perticular?
Old Oct 10, 2007 | 08:59 PM
i really want like a 15x at least 8 in the back hopefully torq thrusts of some type. the front is no biggie
Old Oct 10, 2007 | 09:11 PM
wheelguy's Avatar
I just looked at the website & here are the ones for your Monte.
In front
309-5561 if you want to go 15 x 5 (the smallest they make)
309-5761 for a 15 x 7
In the back
309-58561 for a 15 x 8.5
These will fit perfect (no spacers or any thing) & look real nice.
Old Oct 10, 2007 | 09:14 PM
Thanks!!!! think it will be safe to run 255/60 or 265/60's? or what would the widest tire that youd reccomend be?
Old Oct 10, 2007 | 09:17 PM
how about tt II?
Old Oct 10, 2007 | 09:23 PM
wheelguy's Avatar
On the older cars that is kinda tough, but not imposible to figure out due to shock condition (sagging) and such. The easiest way to figure it out would be to use the below website & put your current tire size in the left spot & the tire you want in the right spot, check how much room you have under the car (outside & inside) & compare it to the specs the site gives you. If you need help let me know, I hope this helps.
http://www.miata.net/garage/tirecalc.html
Old Oct 10, 2007 | 09:29 PM
wheelguy's Avatar
ORIGINAL: KickAss81monte
how about tt II?
You can do the II but there's not much difference. You can get a 10 wide for the back but no 5 up front. The Monte doesn't need any special back side so the II would IMO just prolong the process of getting them because of the build time.
