6th Gen ('00-'05): How wide wheels can i do?
Old Feb 13, 2012 | 05:03 PM
Habbibie's Avatar
Default How wide wheels can i do?
hey guys some of you's here are running 19's n 20's, i wanted to know what is the widest 20 inch wheels i can run? could i run a 20x8.5 up front or has to be an 8in wide max? that with either a positive or zero offset. also what is the widest i can run in the back? looking to see what the widest i can do with out rubbing.. anything i can do to force a 10 inch wide with negative 45 or so offset and wheel spacers but i don't want it to stick out beyond the width of the body? and finally could i use a 35 or 40 series tire with 20's?
PS. my car will be lowered about 2 inches all around.
Old Feb 13, 2012 | 09:48 PM
7801MonteMan's Avatar
With the set up you want to run. 20x8.5 lowered 2" is capable. However, rolled fenders are a must and you might have to run a slightly skinnier tire. You might rub also when you have passengers in the rear.
But 8.5 is the widest you can fit comfortably.
Old Feb 13, 2012 | 10:16 PM
245/35/20 is the tire you'll want to run as well. +35 offset is also around where you want to be.
Old Feb 13, 2012 | 10:46 PM
I honestly would go with 8 to be safe cuz u will be kinda on edge with the 8.5
Old Feb 14, 2012 | 12:14 PM
Ive seen a lot of Monte's and GP's that have 8.5's and they fit just flush. It's the tire size that gets you. There are a couple guys out there that are running 18x9 Mustang wheels that dont look horrible and have slight rubbing issues.
Old Feb 14, 2012 | 01:57 PM
nemesis's Avatar
2009 Monte Of The Year
i do 9" wide that's what i was running on my old monte and yeah you going to have to fender roll for sure if are are lower.
Old Feb 14, 2012 | 01:59 PM
All I can add is that my rims are 8" wide.
Old Feb 14, 2012 | 04:47 PM
Habbibie's Avatar
okay so some here had gone as far as 9 inch wide all around, for that type of set up do i need a camber kit installed on the front? and if i did I'm having no luck finding any anyways....
also the back wheels, i understand i have to roll the fender that's obvious but is 9 inch wide really my limit with out rubbing or having the wheel flare out too much beyond the quarter panel wheel well
Old Feb 14, 2012 | 04:55 PM
Camber kit isn't going to help you with fitment on these cars. All that does is help in the alignment process. But yes 9" is the widest you can go. I would be very careful with going any wider. But typical with the offset we need for our cars, your going to have a hard time finding a 9" wheel anyways. Stick with the 8.5 for the widest wheel.
Old Feb 14, 2012 | 05:25 PM
Habbibie's Avatar
@ 7801Monteman okay i'll take you're advice on the that matter then, sorry to keep bugging you but how wide of a tire could i run in the back if i do 8.5 all around (or you're recommendation on tire sizes for front and wider tires for the back), the look i'm trying to go for is either a wide tire in the back or a more meaty tire in the back, giving it the look of being more a RWD car than an FWD car,
