How to get the right stance?
Old Jul 17, 2014 | 08:19 PM
monte-cristo's Avatar
Default How to get the right stance?
Here is a stock monte
and here is the way I like it.
what do you do to give it this stance? Is it just air shocks or what?
Old Jul 17, 2014 | 08:42 PM
I'm guessing this isn't your Monte but an example on how youd like yours to look?
That is the stock standard ride height and stance IMO...
Unfortunately your 2nd pics link doesn't work... So I have no idea what your trying to accomplish...
Old Jul 17, 2014 | 08:48 PM
ya these are just example cars, not mine. Both pics work for me when I view the thread so I dont know why you cant see it.
Here is a direct link you can just paste into the address bar on your browser. I appreciate you insights.
chooseyouritem.com/classics/photos/4001500/4001630.1974.Chevrolet.Monte.Carlo.jpg
Old Jul 17, 2014 | 09:01 PM
To me ...IMO...
I would say he merely used a larger sway bar to raise it up in the rear and the front is at stock ride height..
Old Jul 17, 2014 | 09:07 PM
To me ...IMO...
do you mean a sway bar from a different kind of car or were there different optional swaybars available?
Old Jul 17, 2014 | 09:09 PM
Heres another stance I like
Old Jul 17, 2014 | 09:26 PM
It could possibly be a high performance sway bar... or an after market heavy duty one.
Old Jul 17, 2014 | 11:20 PM
ohara's Avatar
air shocks will have the effect your are looking for. I used to put them in all of my cars.
Another trick some people use (myself included on one vehicle) is to run 15 inch rims and tires on the back and 14 inch rims and tires on the front, it adds a small subtle drop when coupled with the air shocks. I do recommend getting an alignment if doing this.
You can also buy rubber spacer blocks that go at the bottom of the shocks where they connect, I have never tried these, but it allows you to keep your stock suspension if it is in good condition and you like the ride this may be the better alternative.
The main thing I enjoyed about the air shocks was the height was always adjustable pending you have easy access to an air compressor that has enough psi to raise the car, the down side is (from personal experience) make sure when you put the air lines in, or if you have a shop do it, make sure they use rubber grommets around the lines where they come in contact with any metal as it only takes a small crack in the line to lose all your air and your suspension will drop down, trust me on this one it happened with a 78 camaro that I owned, I was able to limp home but if I had my 12 inch wide tires on the back at the time I would have been stuck on the side of the road, thankfully it was still early spring and I hadn't put them on yet
Old Jul 17, 2014 | 11:46 PM
good advice thanks. Did the air shocks affect your ride smoothness at all? Also, do you put them on the front also or only on the back? What size tires are best to get that stance? I was thinking 235 70 15 on all four wheels which is 27.95" tall. Thanks
Old Jul 18, 2014 | 11:57 AM
here is another one with the stance I like. what size tires do you think they are ?
