GMPP Handling Package
Old Apr 18, 2007 | 11:39 PM
IffyG's Avatar
Default GMPP Handling Package
I was looking around gmpartsdirect and found the W-Body handling upgrade package. I have a completely stock 2002 Monte Carlo SS.
Does anyone know if the car has the upgraded parts already?
Thanks
Old Apr 19, 2007 | 10:16 AM
wiz kidd's Avatar
Default RE: GMPP Handling Package
what does the handling package consist of?? probably nothing different from what you already have ...they just like to make up names for stuff..lol
all the vehicles that i have driven that say they have sport handling package or something like that i haven't noticed a difference to stock ones...i dont know if its just me or if anyone else notices this
are you not happy with the way your monte handles??
Old Apr 19, 2007 | 10:56 AM
rchurch's Avatar
I looked in to getting the GMPP kit, but didn't think it was that much different from stock. I ended up putting together a suspension using Eibach springs, KYB struts, and SLB sway bars. The GMPP kit was WAY cheaper, but I think my suspension is much better.
Old Apr 19, 2007 | 12:07 PM
IffyG's Avatar
As best I can tell the trailing arms on the car now are just some rolled sheet metal. The GMPP trailing arms look completely different (rounded).
I have looked into SLP sway bars and some BMR suspension parts as well, but they are way too expensive. Even if the GMPP kit doesnt make the car rock solid, it will at least be more fun to drive. The bang for the buck factor is my main concern.
rchurch, do you have any pogo problems with the Eibach springs and the KYBs (are they the standards or the AGX adjustables?)
Thanks
Old Apr 19, 2007 | 12:11 PM
IffyG's Avatar
Shoud have put this in the last post, but wiz kidd, I really like how the car handles when im just driving around town, but sometimes if I'm pushing it a little harder than usual, the back end starts to get a bit funky on me. I'm just looking for a way to tighten up the back end under tight cornering.
Old Apr 19, 2007 | 03:38 PM
rchurch's Avatar
They are the standard KYB's. No pogo'ing at all. I do want to go with the adjustables when I replace them, just for the adjustability. Before I put the SLP sway bars on it did get funky in the rear in hard cornering but the bars stopped that. I wouldn't mind the round trailing arms, the stock stamped steel ones are flimsy.
Old Apr 19, 2007 | 08:21 PM
2003 SS's Avatar
I just purchased the Eibach spring kit - I have the round trailing arms on order. I'm just trying to figure out what I need for strut mounts - I'm going with the KYB struts... I'll keep you posted as I make progress!!
Anyone who has installed theEibach spring kit and struts- did you change the mounts? If so, can you use stock strut mounts or do you need anything special. Am I going to have the "pogo" issue??? - just trying to get everything straight before I do it.
Thank
Old Apr 19, 2007 | 10:55 PM
mickey's Avatar
ok can someone please explain this POGO issue that were all hearing about?
What is it?
what or how can you fix it?
Is this with the stock struts and the lowerd springs also?
Also do any of ya have alink to the trailing arms?
I would love to get this car tighter. I havent had a issue with it tryign to come around on me and i hit a 30mph cornner every day at more like 55-65 but at the same time i also like the idea of it beign a bit less body roll.
I hate that i cant get it flat in a corrner. this is the biggest comeplaint for me other then the non exsitance of the V-8 and RWD with a better tranny in it.
Old Apr 20, 2007 | 10:36 AM
rchurch's Avatar
Trypfyc.com. As I've posted several times, I have the Eibach springs, KYB non-adjust struts and SLP sway bars. I'm also running 255-45 z rated tires on 8.5" x 17" rims. I can push the car to the tires limit in a corner and it stays relatively flat. Before I put on the sway bars, the car wold feel like it wanted to "hop" in the rear when really pushing it in a corner and understeer was terrible. I felt like it was the stamped steel cheapo trailing arms flexing. Now I'm wondering if this was the "pogo'ing" effect everyone talks about. It didn't happen in normal driving, just pushing the car hard in a turn. With the sway bars it doesn't happen and the understeer isn't nearly as bad, but I still want to replace the factory trailing arms. I just think it will complete the suspension and tighten it up a bit more.
Old Apr 25, 2007 | 10:19 AM
Donutboy97's Avatar
Monte Of The Month - April 2010 & Sep
ORIGINAL: IffyG
Thanks
I would recomend getting this. Some of the newer MC's (like the 06+ SS have some of the parts) but this will be an improvement for your MC. you can even run the Comp G rear sway which is solid... I have to get the pt number later though.
